Tom's Hardware > Forum > Mobility Networks > Verizon > Phone work in Nassau, Bahamas?
Forum Mobility Networks : Verizon - Phone work in Nassau, Bahamas?
Archived from groups: alt.cellular.verizon (More info?)
America's Choice 500 plan.
Will my phone work in the Bahamas?
Roaming?
Thanks,
Dean
Sponsored Links
you should be OK- you may have to set it to the "A" mode if you are not getting
a signal.. ( settings- system settings, etc.- )
you will get roaming of at least .69-.99 /minute, but I would call cust care
(*611) before you go to double check on that-
Reply to Anonymous
Batelco (Nassau, the Bahamas) is TDMA and AMPS, while Verizon is CDMA and
AMPS. Your phone will work there in the AMPS mode however, Batelco is not a
roaming partner with Verizon. You will need to go to the local Batelco
office in person and make roaming arrangements. This will probably involve
assigning a Batelco number to your phone for the duration of your visit.
"Dean" <dean173@yahoo.com> wrote in message
news:cYm8d.446$Ua.431@trndny01...
> Roaming?
> Thanks,
> Dean
Reply to Michael
There are 1309 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
