Solved
Dead Space 2 Problem(s)
  • PC gaming
  • Video Games
Last response: in Video Games
February 15, 2011 10:09:19 PM
Hello there my mother picked up a copy of Dead Space 2 for the PC for me today (oh yay time to get scaryed shitless : D) anyways i install it with the 2 discs and enter in my EA account and redeem my online pass... i play single player to find it was very laggy so i lowered the settings to lowest but kept my resolution at 1280x720 that seemed to fix my FPS problem until i got to the guy who cuts you out of your straight jacket (SPOILER SORRY, I think) and it seemed like my game started Skipping Frames. so i ignored that problem since it didn't seem to happen to much in gameplay.
But later on you get to this point where theres a Shadow on the wall and it's just a manikin on a table with a flashlight making the shadow, so i turn to the flash like and i realized "why is everything bouncing around?" what i mean is the flashlight was like jumping and jitting in spot and almost knocking itself off the table/shelf thing. and the room just before it i had to kill some enemies and when they died there ragdoll phys just kept jumping around like the flashlight and manikin. could someone please answer why this is happening
Settings:
Resolution: 1280x720
V-Sync: Off
Graphic settings: Low
Specs:
AMD Athlon 64 x2 5600+ (Brisbane) OC'd to 3.0ghz
Ati Radeon HD 4350 512mb (Could this be the problem i know it's a bad card)
2Gb Lexar 800mhz DDR2 Ram
160Gb Harddrive
500Watt Thermaltake PSU
More about : dead space problem
February 16, 2011 2:23:24 PM
This seems like a problem with the texture loading. No need to panic, can you restart from your checkpoint or something ? I don't have Dead Space 2 , I only have the first version. Dead Space 1, seemed to have almost a same problem. The dead bodies, just kept on jittering no matter what. I suggest you just load back from your save games.
m
l
February 16, 2011 6:00:30 PM
I will try both suggestions and will report back
m
l
February 16, 2011 7:42:07 PM
Okay so i turned V-sync on as much as i hate it, and reloaded my save i backtracked to where the flashlight was on the table and the manikin and well they were both on the ground not moving or jittering. so i was like cool i went back and saw a body on the ground and used telekinesis and picked it up and through it at the wall it fell down and then it kept jittering a bit, not as bad as the flashlight and manikin though...
I Was running Fraps and my FPS Was:
Min:20
Avg:25-30
Max:35-40
So i don't think it is really an FPS problem? (thats with Vsync on and lowest settings at 1280x720)
m
l
Best solution
February 22, 2011 12:30:41 AM
Im sorry to inform you that you have a slow piece of crap video card that should not be used to play games even at 800x600 res. Buy at least a gts450 or HD 5750. If your really short on cash even a 5570 or gt240 would be significantly better than what you have and should play the game ok at that resolution with medium detail.
February 22, 2011 12:33:06 AM
Lol oh i know, don't worry i'm getting a GTS 250 and as far as i know it can play Crysis 1 Maxed out at 1280x1024 (no AA/2x AA) and Crysis 2 Aswell (youtube video)
m
l
February 22, 2011 12:33:14 AM
Best answer selected by mithness.
m
l
