Tom's Hardware > Forum > Systems > HP > Puzzled by a problem
Forum Systems : HP - Puzzled by a problem
Archived from groups: comp.sys.hp.hardware (More info?)
I have been having this problem and I have no idea if I had a virus or
a hardware problem. My "p" key on my hp notebook doesn't work and
whenever I start the computer, this key is automatically held down by
the computer itself. Not sure if I'm explaining it well. Basically the
computer is doing this on it's own: "pppppppppppppppppppppp ....". It
used to be the "y" key but after I reformatted my HD (for an unrelated
problem) it was ok for a while and now it's the "p".
Sponsored Links
Possibly a failing keyboard assembly. Could be simply the microswitch for the
letter p. Any dust, dirt, or goo find its way inside the keyboard?
.... Ben Myers
Reply to Anonymous
microswitch for the
> ... Ben Myers
I don't think it's because of any dust or dirt since I always keep the
monitor down. If it was the keyboard assembly or microswitch, would it
be easy to fix?
Kyra
Reply to Anonymous
If you have the service manual for the computer, it's not too hard. Just a
little tedious, fiddling with teeny-tiny screws and other small parts not
intended for handling by larger-than-a-child's hands... Ben Myers
On 12 Apr 2005 09:21:02 -0700, kyra@mailtag.com wrote:
>microswitch for the
>> ... Ben Myers
>be easy to fix?
>Kyra
Reply to Anonymous
There are 1215 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
