Tom's Hardware Forums » Mobile Computing » General Mobile Computing » Which battery is better?
Add a reply
 Word :   Username :
Bottom
Author
 Thread : Which battery is better?
Profile: newbie
More Information
I'll be buying a Dell Inspiron 9300 soon, and as I customise it I come across the primary battery which is a 6 cell, 53WHr model.
Then further down it has a second primary battery which is a 9 cell 80WHr model.
My question is which is better and why?
Related Pr oduct
Profile: Honorary Master of THGC
More Information
9 cell 80wHr model holds more energy and has larger capacity.
The cells refer to the number of batteries inside brick and the wHr is watts per hour.
Watt Hour (wHr) - Electrical power measured in terms of time. One watt hour of electricity is equal to one watt of power being consumed for one hour. (A one-watt light operated for one hour would consume one watt hour of electricity.)
So bigger is better is longer runtime before auto shutdown.
<pre><font color=red>°¤o,¸¸¸,o¤°`°¤o \\// o¤°`°¤o,¸¸¸,o¤°
And the sign says "You got to have a membership card to get inside" Huh
So I got me a pen and paper And I made up my own little sign</pre><p></font color=red>
Profile: newbie
More Information
thanks. I thought so.
But then why offer the 9cell battery for less than a second 6cell battery?
Add a reply
Google Ads
