G
Guest
Guest
Hi there i have a Jetway 663AS motherboard with 663asa03.bin 4/10/2000 bios and i am trying to reflash my bios as at times my system is not too stable ...
I have no problem with the board as i like it but when i try to reflash my bios with the instructions in the manual using awdflash.exe when i type in the msdos line
Awdflash A:\663ASA06.bin/sn/py/cc/r/nbl
or
All that happens is a help screen comes up telling me about the different switches etc ...
When i actually run Awdflash.exe first then try then i get as far as it is asking me if i want to save my old bios settings when i say no i get the error message ...
The program files bios lock string does not match your system ...
I am using the Awdflash.exe from the Jetway website and the 663ASA06.BIN and following the instructions thoroughly and i cannot get the required results can anyone tell me what is wrong ?
Thank You In Advance ...
Darren
or
Darren
