G
Guest
Guest
Hi all. I just finnished putting together a new system and I would like advice on a fairly specific problem.
The system:
Socket A Tbird 750
Chrome Orb Fan
Chaintech AJA100 mobo (audio disabled)
128 mb pc 133 (one stick)
Abit Siluro GeForce 2 MX (32 mb)
SB Live!value
6gb Fujitsu 7200 RPM HD (IDE)
Matsushita CD-RW (IDE)
Floppy
AT 2500 TX nic
Generic Case w 300 watt power (ATX)
The problem:
After about an hour or so, if I try to do any large access to the CD (more than about 2 minutes of access) the machine locks up tight. I have to power down from the case switch about half the time (ctrl-alt-del doesn't work). This doesn't seem to affect HD access, as I can continue to game, so long as the machine doesn't need to read from the cd to much.
I have swapped out the mobo, the hd ,the cdrom, the IDE cables. I also swapped in a 250w Power supply, which made things worse (obviously too small).
The question:
So I pretty much think this is power issue, as the smaller power suply amplified the problem. The question is a new 300w or do I just bite the bulit and get a 330? Anybody else had this issue with this mobo?
Thanks.
The system:
Socket A Tbird 750
Chrome Orb Fan
SB Live!value
Floppy
AT 2500 TX nic
The problem:
The question:
Thanks.
