G
Guest
Guest
Hello,
I just assembled my own machine with A7V133 mobo, 900 MHz Athlon, Asus 7700 graphics card and IBM DTLA-307030, UltraATA/100, 30GB, 7200RPM HDD
Most of the things are working right except following two problems
1. Promise Ultra 100 BIOS (latest version) does not detect my hard-drive. After going through its "detect" step, it reports that it could not find any devices and therefore does not load. I thought it should detect the HDD. Correct me if I am wrong.
2. My CPU temperature is also quite high in mid 50s (without overclocking) with Swiftech MC370-0A. I am using a thermal compound for better contact. It appears that the cooler is sitting snugly on the CPU. Maybe I need to make it more tight ?? Any recommendations ?
Thanks a lot.
Thanks a lot.
