I just put together a new system and its working fine except for the following message at boot up: "ULTRA 100 BIOS NOT INSTALLED BECAUSE THERE ARE NO DRIVES ATTATCHED"
I downloaded a current 4in1 driver and I still get that message at boot up. Any ideas what the problem could be?
1.2 Ghz T-bird
ASUS A7V133
256 MB SDRAM
PIONEER DVD
HERCULES ULTRA VIDEO CARD
The A7V133 has 4 IDE connections. I do not have the board but I am almost certain you are getting this line because you are not using at least two of them. The "error" just means that the two additonal IDE ports you have are not in use and will be disabled. If you don't need them this is best because it will free up interrupts in windows. Don't worry I believe it is normal.
At bus stations, busses stop. At train stations, trains stop. My desk has a work station. GO FIGURE!
I own an asus a7v do you have a problem with that? Personally I think it is one or the better mb’s I have ever worked with. I only wish I would have got an A7V133 but they were not out when I bought mine.
Heres how the A7V133 works,
There are 4 IDE connectors onboard, 2 by themselves which are DMA 100 and Raid compatible and 2 above the floppy connector which are DMA 100 non raid.
If you plug a harddrive into one of the IDE ports that are above the floppy port(non raid) your drive will be seen by the bios and not the promise drivers as IDE 33/66/100 H/D and will result in the Promise driver(which loads after the regular bios)not to detect the device, hence telling you "no device found" when the Promise diver loads.
If you plug your H/D into the Raid DMA 100 ports (the two that are not by the floppy port) then your bios will not detect IDE H/D but the promise Driver will see it and load your ultra DMA 33/66/100 device depending on what you have.
To set up 2 harddrives in raid 0 format you need to set jumpers 13 an 14 from the default setting of 1-2 to raid setting of 2-3 then plug the 2 drives into the DMA 100 Raid ports each with its own DMA 66/100 IDE cable.
One cable (blue end) into the primary raid port (black end) into one of the h/d's and other cable (blue end) into the secondary raid port (black end) in to 2nd H/D . When you start the system for the first time after setting up the system as stated above your A7V133 promise raid driver will see the 2 drives and prompt you to set up your array. Its all auto so no problem there. Just follow on screen instuctions.
After you setup the raid array your system will see the 2 drives as 1 drive. You will have to Fdisk and Format the array before you load an OS.
Lastly, with the IBM 75GXP DMA 100 drives and most likey most DMA 100 h/d's you should set your jumpers on the h/d as cable select not master. This will allow the h/d to be seen as being connected to a DMA 66/100 cable and mobo and or Raid card.
Not sure on one thing. The A7V133 is really similar to the A7V with regard to disk controllers. The difference being that the A7V133 is jumpered to use either ATA100 or RAID0. I thought the two sets of IDE connectors were ATA100/RAID0 and ATA33 (next to the FDD). I know that for sure on the A7V since my old setup would only run with the HD on the ATA33 controllers. Can someone confirm or deny this??
Either way, I am running ATA100 off of the first set of IDE connectors and have the RAID0 turned off on the A7V133.
I have a 30GB IBM DESKSTAR attached to the (non raid) IDE port. I guess thats why I get that message at boot up. In the future I will buy a second hard drive and set up RAID. For now I will ignore that message.
You can use any of the 4 IDE ports on the A7V133 with a single h/d drive. Just leave the jumpers on the default of non raid, plug a H/D into the IDE by the floppy port and it will say no device found when you boot up because you Bios auto detects and sees the H/D before the promise divers loads.
Plug the H/D into one of the IDE ports not by the floppy drive and your bios wont see a H/d but your promise driver will and it will post....
01 XXXXXX x= name of device
02 no device
03 no device
04 no device
You can plug a single drive into the Raid port on the mobo and the Promise driver will load using ultra DMA 100.
I just tried moving the HD from the port next to the floppy to the raid port. The computer boots up and the promise driver detects the HD. The problem is the computer locks up at the WIN98 screen. I moved the HD back to the non raid port and the computer boots up fine. I do have the current promise driver loaded.
