I am buying this component to VGA to use my original xbox on my monitor. It says its HD 1080p but I dont know if my monitor will work with it because I don't know if my monitor has 1080p. My monitors resolution is 1280 by 1024, is that HD? Its a dell monitor.
Heres the component to VGA:
http://www.amazon.com/Component-Converter-Connected-Computer-Projector/dp/B003VJ9QWA/ref=sr_1_11?s=electronics&ie=UTF8&qid=1302020936&sr=1-11
Thanks!
To sum this up, just tell me if the adapter will work on a monitor with a 1280 by 1024 resolution.
Thanks!
