Tom's Hardware > Forum > Systems > HP > HP Printer Installation Help
Archived from groups: comp.sys.hp.hardware (More info?)
usenet@twmi.rr.com May 5, 2:27 pm show options
Newsgroups: comp.unix.solaris
From: "use...@twmi.rr.com" <use...@twmi.rr.com> - Find messages by this
author
Date: 5 May 2005 11:27:04 -0700
Local: Thurs,May 5 2005 2:27 pm
Subject: HP JD Printer Installation Problems Help
Reply | Reply to Author | Forward | Print | Individual Message | Show
original | Remove | Report Abuse
I have tried to add a HP LaserJet 4050 Network printer using 'hppi' of
HP JetDirect s/w HPNPL E.10.34. But I am unable to add the printer
using the 'Create Pinter configuration in BOOTP/TFTP database'. I get
the following on the screen
Probing the hardware interface for identity. This could
take few seconds....
Problem encountered during this process which could be one of the
following:
1] The device is not in the network
2] The device is already configured with another IP address,
(thro DHCP/BOOTP), Remove it and start again.
3] Hardware interface is not an official HP Jetdirect
Take a test page of the Jetdirect from the printer.
If you see no IP address assigned, or if it is 0.0.0.0,
wait for around 5 minutes. It will default to
192.0.0.192(if it is HP jet direct) This will help in
identifying the Hardware interface and continuing the
configuration.
The only way I could get the printer to work was to manually add the
printer's MAC etc... /etc/bootptab and then add a printer using add
printer under spooler administration
Any suggestion/help is greatly appreciated
Sponsored Links
There are 549 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
