Archived from groups: alt.internet.wireless,uk.comp.home-networking (More info?)
I just bought a Belkin Wireless G USB adapter F5D7050UK and loaded it on two
computers (desktop and laptop) and I can't get either to go faster than
11Mbps.
The adapter is now sitting on top of the Linksys WRT54G router, so range
isn't an issue. Other computers in other rooms connect happily at 54Mbps.
I use Windows XP SP2 and WEP 64-bit security. It connects immediately.
I've also tried downloading and installing the latest drivers from the
Belkin web site.
Any ideas? Anyone else with one of these gizmos that has it running at its
rated speed?
Archived from groups: alt.internet.wireless (More info?)
What are you trying to measure? File transfers between computers or
download speed from the Internet?
If the latter, you are at maximum speed. 54 refers to file transfers only.
"Jonathan Eales" <Jon.Eales@Virgin.net> wrote in message
news:lYnpd.550$3u5.311@newsfe5-win.ntli.net...
>two computers (desktop and laptop) and I can't get either to go faster than
>11Mbps.
> Belkin web site.
> its rated speed?
> Jonathan
Make sure you have B/G option checked and if you have super G mode check
that and lastly use G static mode and not dynamic mode
>11Mbps.
> Belkin web site.
> its rated speed?
> Jonathan
Thanks Guys, for your suggestions but the problem is fixed. If you use the
supplied stand the speed is capped at 11Mbps, yet if you push the adapter
directly into the USB socket the reported speed immediately jumps to 54Mbps.
Go figure! Tried this on both computers and it works.
Jonathan
"Jim" <jcmios@n-connect.net> wrote in message
news:10qch3nru96k357@corp.supernews.com...
>>than 11Mbps.
>> 54Mbps.
>> Belkin web site.
>> its rated speed?
>> Jonathan
On Fri, 26 Nov 2004 06:19:01 GMT, "Jonathan Eales" <Jon.Eales@Virgin.net> wrote:
>Jonathan
<snip>
Sounds to me like the "stand" may be using a USB 1.1 rated cable.
Can I guess? The stands were USB 1.1 only. The computah thinks it's
talking to a USB 1.1 device and limits the speed. Max on USB 1.1 is
12Mbits/sec, which is far too close to 11Mbits/sec for comfort. Dump
the stand and plug in directly to a USB 2.0 port, and you get full
speed. Most of the other USB 802.11g data sheets include warnings of
diminished thruput when used with USB 1.1.
Jeff Liebermann jeffl@comix.santa-cruz.ca.us
150 Felker St #D http://www.LearnByDestroying.com Santa Cruz CA 95060 AE6KS 831-336-2558
