Problems with Wow lagging and freezing using a EVG A P55 SLI
Last response: in Video Games
Hi,
I am at my wits end trying to figure out what is wrong. I bought this PC from Harvey Norman and I was very excited. I thought WOW would be awesome on this 12 gig gaming ram, and it has 2 Nvidia graphics cards.
But it is running as if I have only 1 or 2 mb ram.
I have included this information in the hopes it helps you know what I have and what the problem might be. Any help would be very appreciated :)
NVIDIA System Information report created on: 04/18/2011 16:28:05
System name: LAURA-PC
[Display]
Operating System: Windows 7 Home Premium, 64-bit (Service Pack 1)
DirectX version: 11.0
GPU processor: GeForce GTX 460
Driver version: 266.58
DirectX support: 11
CUDA Cores: 336
Core clock: 720 MHz
Shader clock: 1440 MHz
Memory clock: 1800 MHz (3600 MHz data rate)
Memory interface: 256-bit
Total available graphics memory: 4095 MB
Dedicated video memory: 1024 MB GDDR5
System video memory: 0 MB
Shared system memory: 3071 MB
Video BIOS version: 70.04.13.00.76
IRQ: 16
Bus: PCI Express x8 Gen2
DirectX support: 11
CUDA Cores: 336
Core clock: 720 MHz
IRQ: 16
[Components]
nvui.dll 7.17.12.6658 NVIDIA User Experience Driver Component
nvxdsync.exe 7.17.12.6658 NVIDIA User Experience Driver Component
nvxdplcy.dll 7.17.12.6658 NVIDIA User Experience Driver Component
nvxdbat.dll 7.17.12.6658 NVIDIA User Experience Driver Component
nvxdapix.dll 7.17.12.6658 NVIDIA User Experience Driver Component
NVCPL.DLL 7.17.12.6658 NVIDIA Compatible Windows Vista Display driver, Version 266.58
nvCplUI.exe 3.5.797.0 NVIDIA Control Panel
nvWSS.dll 6.14.12.6658 NVIDIA Workstation Server
nvViTvS.dll 6.14.12.6658 NVIDIA Video Server
NVSTVIEW.EXE 7.17.12.6658 NVIDIA GeForce 3D Vision
NVSTTEST.EXE 7.17.12.6658 NVIDIA 3D Vision Test Application
NVSTRES.DLL 7.17.12.6658 NVIDIA 3D Vision Module (0)
NVMCTRAY.DLL 8.17.12.6658 NVIDIA Media Center Library
nvDispS.dll 6.14.12.6658 NVIDIA Display Server
PhysX 09.10.0514 NVIDIA PhysX
NVCUDA.DLL 8.17.12.6658 NVIDIA CUDA 3.2.1 driver
nvGameS.dll 6.14.12.6658 NVIDIA 3D Settings Server
Also some system temps when idle and under load to make sure your system is not throttling back, can you actually give us a link to your system online anywhere, so we can actually see what you have bought ?
Related ressources
Type Dxdiag into the run box and all the information will come up under system information.
Its the search box that comes up when you click the start bar, not 100% sure if its in the same place for Windows 7 as I have Vista.
Ok, I googled what I could.
I downloaded speed temp program.
Without WoW opened and PC only been on for 10 minutes by this time. Temps read at
GPU 30c
GPU 27c
System 15c
CPU15c
AUX 41c
HD0 22c
Core0 19c
Core1 20
After WOW had been on and I watched the framerate start at 60 and drop to 0 within 2 minutes. By this time I could not move a step.
GPU 34c
GPU 28c
System 21c
CPU 21c
AUX 41c
HD0 23c
Core0 27c
Core1 23c
CPU0 865 RPM
In my PC I am running the V8 Cooler so in theory this should be very adequate.
I will do the system specs shortly.
I ran Belaric Advisor. I love that program.
I believe this should be the specs of my PC.
System Security Status CIS Benchmark Score
Available only for Windows 2000, XP Pro, and 2003
Virus Protection
Up-to-date
Microsoft Security Updates
Up-to-date
Computer Profile Summary
Computer Name: Laura-PC (in HOMEGROUP) — Laura-PC
Profile Date: Tuesday, 19 April 2011 8:39:10 AM
Advisor Version: 8.1p
Windows Logon: Laura
Plan for your next computer refresh...
click for Belarc's System Management products
Operating System System Model
Windows 7 Home Premium (x64) Service Pack 1 (build 7601)
Install Language: English (United States)
System Locale: English (Australia) Enclosure Type: Desktop
Processor a Main Circuit Board b
2.93 gigahertz Intel Core i7 870
32 kilobyte primary memory cache
1024 kilobyte secondary memory cache
8192 kilobyte tertiary memory cache
64-bit ready
Multi-core (4 total)
Hyper-threaded (8 total) Board: EVGA 120-LF-E650 Rev 1.xx
Serial Number: 103772830000416
Bus Clock: 133 megahertz
BIOS: American Megatrends Inc. 0403 03/31/2010
Drives Memory Modules c,d
4000.79 Gigabytes Usable Hard Drive Capacity
3825.26 Gigabytes Hard Drive Free Space
SAMSUNG DVDWBD SH-B083L ATA Device [Optical drive]
HP Photosmart B109a USB Device [Hard drive] -- drive 2
WDC WD20EARS-00MVWB0 [Hard drive] (2000.40 GB) -- drive 1, s/n WD-WMAZA3126034, rev 51.0AB51, SMART Status: Healthy
WDC WD20EARS-00MVWB0 ATA Device [Hard drive] (2000.40 GB) -- drive 0, s/n WD-WMAZA3134058, SMART Status: Healthy 12280 Megabytes Usable Installed Memory
Slot 'DIMM0' has 2048 MB (serial number SerNum00)
Slot 'DIMM1' has 2048 MB (serial number SerNum01)
Slot 'DIMM2' has 4096 MB (serial number SerNum02)
Slot 'DIMM3' has 4096 MB (serial number SerNum03)
Local Drive Volumes
c: (NTFS on drive 1) 2000.40 GB 1825.02 GB free
d: (NTFS on drive 0) 2000.40 GB 2000.24 GB free
Network Drives
None discovered
Users (mouse over user name for details) Printers
local user accounts last logon
Laura 19/04/2011 7:43:56 AM (admin)
local system accounts
Administrator 6/01/2011 2:40:01 AM (admin)
Guest never
HomeGroupUser$ never
Marks a disabled account; Marks a locked account HP Photosmart B109a-m on USB001
Microsoft Shared Fax Driver on SHRFAX:
Microsoft XPS Document Writer on XPSPort:
Send To Microsoft OneNote 2010 Driver on nul:
Controllers Display
ATA Channel 0 [Controller]
ATA Channel 1 [Controller]
ATA Channel 2 [Controller]
ATA Channel 3 [Controller]
ATA Channel 4 [Controller]
ATA Channel 5 [Controller]
Intel(R) 5 Series/3400 Series Chipset Family 6 Port SATA AHCI Controller - 3B22 NVIDIA GeForce GTX 460 [Display adapter] (2x)
HP 2310e [Monitor] (23.1"vis, s/n 3CQ041271C, October 2010)
Bus Adapters Multimedia
Intel(R) 5 Series/3400 Series Chipset Family USB Enhanced Host Controller - 3B34
Intel(R) 5 Series/3400 Series Chipset Family USB Enhanced Host Controller - 3B3C
Intel(R) 5 Series/3400 Series Chipset Family USB Universal Host Controller - 3B36
Intel(R) 5 Series/3400 Series Chipset Family USB Universal Host Controller - 3B37
Intel(R) 5 Series/3400 Series Chipset Family USB Universal Host Controller - 3B38
Intel(R) 5 Series/3400 Series Chipset Family USB Universal Host Controller - 3B39
Intel(R) 5 Series/3400 Series Chipset Family USB Universal Host Controller - 3B3B
Intel(R) 5 Series/3400 Series Chipset Family USB Universal Host Controller - 3B3E
Intel(R) 5 Series/3400 Series Chipset Family USB Universal Host Controller - 3B3F NVIDIA High Definition Audio (8x)
Realtek High Definition Audio
Don't laugh. But I ran Runescape to test it. Yeah I know, a big gaming PC and I go on RS. But it ran it perfectly. I have tested offline games and yeah it runs it sweet as.
This thing cost me 4 grand by the time I got the monitor too so I am a bit upset that there must be one simple thing impeding on WOW. I should in theory run it fine and above fine.
The case I think is extreme. It has Extreme written on the front when I open the door. The face is similiar to that of alienware style. Blue lights and a clear plastic side. This was meant to be my ulitmate gaming machine.
Sorry I cannot find a picture. I looked on the Harvey Norman site but because they built this, I don;t think they have a standard pic of it.
Ask the community
