Tom's Hardware > Forum > Motherboards & Memory > General Motherboard > help, upgrading old Gateway... need duron info
Forum Motherboards & Memory : General Motherboard - help, upgrading old Gateway... need duron info
I am currently running a Gateway G-266 PII with 64 mb of ram. The system is mainly used for business and accounting and not much gaming. I would like to upgrade the system because my software if really lagging, and I would like to do it for less than $300. I was wondering about adding a 850 mhz duron with a new giga byte mobo and PC100 128 mb of RAM. Would this be sufficient for the money or do I need more power? How easy would it be to overclock this system to 1 ghz and what type of cooling system would I need? Are durons good buys or would you suggest that I go with a low speed athlong with a 266 mhz fsb for future upgradability? I am planning on using my old video card, 4mb AGP and gateway sound card. I also plan on keeping the 9gb of harddrive space wich in almost four years I still have 4gb free. I priced adding an 850 mhz duron, giga byte mobo, and 128mb of ram at about $210 dollars. Without going over $300 what else would give me the greatest bennefits for bussiness aps? Any help is greatly appreciated. Also any info on overclocking the Duron would be helpful. BTW what is a good motherboard buy for this chip and for overclocking?
Thanks for your time
madison
mmcmajor@apex.net
Sponsored Links
Look into Asus, go with DDR because it is cheap now, yes you can use PC2100 on a DDR motherboard with a Duron, and with DDR you won't have to worry about buying a new motherboard next time you want to upgrade processors. Get your DDR from Crucial. The A7M266 is a top performer, using the AMD 761 northbridge and the slighlty disreputable VIA southbridge. The A7A266 is a good option offering better stability and campatability, but with slightly less performance and uses the ALi MAGiK1 chipset.
Suicide is painless...........
Reply to Crashman
read my response to your other post...
Reply to ledzepp98
There are 850 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
