Sign-in / Sign-up
Troubleshoot my problem with new installed window 7
  • Windows 7
Last response: in Windows 7
Anonymous
a b $ Windows 7
September 22, 2010 7:00:49 PM
Hello,
I often see a blue error screen showing "dumping physical memory".After installing window 7. Before this Window XP professional was working well on my machine. i generally get this blue screen while using internet. I tried ready boost to increeat performace but it didn't help.
My PC configuration is:
Manufacturer System manufacturer
Model System Product Name
Total amount of system memory 1.00 GB RAM
System type 32-bit operating system
Number of processor cores 1
64-bit capable Yes
Total size of hard disk(s) 34 GB
Disk partition (C:)  19 GB Free (34 GB Total)
Display adapter type Intel(R) G33/G31 Express Chipset Family (Microsoft Corporation - WDDM 1.0)
Total available graphics memory 251 MB
Dedicated graphics memory 0 MB
Dedicated system memory 64 MB
Shared system memory 187 MB
Display adapter driver version 8.15.10.1749
Primary monitor resolution 1024x768
DirectX version DirectX 9.0 or better
Network Adapter Realtek RTL8168C(P)/8111C(P) Family PCI-E Gigabit Ethernet NIC (NDIS 6.20) .
Please help me. by troubleshooting my problem
More about : troubleshoot problem installed window
a b $ Windows 7
September 22, 2010 7:29:59 PM
TURN READY BOOST OFF, then run the computer till it crashes, what are you doing at the time of the dump(we call it a BSOD(Blue Screen Of Death), because the back ground color is blue, download bluescreenviewer and use it, tell us what it says
http://www.softpedia.com/progDownload/BlueScreenView-Do...
m
l
a b $ Windows 7
September 22, 2010 8:54:35 PM
Run memory check, W7 is much more fussy about memory modules then W2000. More ram would be usefull if your board can handle it, but unless you can get it realy cheap it's not worth spending too much on that system.
Start saving for a new pc.
m
l
