Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Problems connecting to FTP
As the subject says, I am having problems connecting to my FTP site from my office.
The FTP server is set up on a Windows 2000 Small Business Server using Serv-u FTP. I have the proper ports forwarded on my router.
When I try to connect using IE, I get the login/password box, which accepts my information, but then I get an error "An error occured opening that folder on the FTP Server. Make sure you have permission to access that folder. Details: The operation timed out".
The computer I am using to try and connect is running XP Pro SP1.
The other weird problem is that I can connect to it from other computers, both in the office and other locations. Is there something in the setup of XP Pro?
Systems Running F@H:
AMD: [A64 3200+] [XP2800+] [XP2400+]
Intel: [P4 2.8 x3] [P4 1.8] [P4 1.7] [P4 1.6 x2] [P4 1.4M] [Xeon 1.0] [Cel 1.0] [P3 ??]
Sponsored Links
Found the problem...seems under Tools->Internet Options->Advanced, the "Use Passive Mode FTP (for firewall and ADSL compatability)" needs to be turned OFF. So it should read something like "Use Passive Mode FTP (for firewall and ADSL INcompatibility)"
F@&%#&^% Microsoft.
Reply to sparky853
1 hour 4 minutes to solve your own problem.
Not bad..
Riser
Reply to Riser
There are 626 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
