G
Guest
Guest
I just got a new setup that I'm putting together, but I can't seem to get the thing to start up. When I plug it in and turn on the ATX ps, the power LED on the mobo lights up, but then no amount of fiddling with the power switch, reset switch, or any other switch I can find will get the system to start. The chipset fan and CPU fan never start running, and there is no indication of anything getting power other than the LED on the mobo.
I've stripped it down to just the following components:
- Asus A7V133 mobo
- Duron 800
- 256 MB Micron PC133 memory
- IBM 8.4GB HD (salvaged from old system)
- Asus V3800 TNT2 Ultra video card
I've tried removing all of these except the processor, and still no juice. I've checked the BIOS reset jumper, the case intrusion jumper, and the power switch itself, and everything looks as it should.
I'd appreciate any words of wisdom that might send me down the right path.
- Asus A7V133 mobo
- Duron 800
