Any way to extend range of internal wireless PCI card in PC?
Last response: in Wireless Networking
Anonymous
Wireless Authority
Archived from groups: alt.internet.wireless (More info?)
I assume things like a Hawking antennas are normally placed on a
router.
Can they be connected to a remote Desktop PC as well? Example: One on
the wireless router and one on the wireless (remote - another part of
house) PC to gain maximum ability to pick up a signal? Or does it just
need to be on the router?
Are there any products without changing to USB (where you can put unit
on top of a table or move it around a little) to provide a better
signal off the PC Wireless PCI Card antenna (back of PC)?
Perhaps take that antenna off of PC and attach a cable that can extend
3 feet perhaps to an antenna type base on top of a table or
somewhere...I am sking if such a product exists or should I just go
USB to get antenna where it needs to be?
Thanks, Patty
Anonymous
Wireless Authority
You didnt say what kind of pc card, but linksys offers
an antenna stand with 6 foot cable...........
http://www.linksys.com/products/product.asp?grid=33&sci...
and the antenna
This is linksys specific though.
Each manufacturer has a differnet antenna connection (by fcc rules)
so you may have to buy a pigtail with the proper connections on both
ends.
"Patty Amas" <pattyjamas@hotmail.com> wrote in message
news:e5e9337.0411300747.22e9bc9@posting.google.com...
> router.
on
of
just
unit
extend
> Thanks, Patty
Anonymous
Wireless Authority
Hi,
Netgear also has a card that clames an external antenna, the WAG311.
I am in the market for a PCI card myself but will probably go for the
less expensive WG311T, as I live in a small condo and don't need the
added range.
--Al
In article <e5e9337.0411300747.22e9bc9@posting.google.com>,
pattyjamas@hotmail.com says...
> router.
> Thanks, Patty
Ask the community
