G
Guest
Guest
i just bought a asus a7v board rev 1.05 it doesnt have a fan on the chipset heatsink. also, on the cpu voltage jumpers, the online help shows vid 4,3,2,1 in this order from top to bottom. jumperfree being all on pins 3 and 4.mine has vid 1,2,3,4 from top to bottom? when i change to user define cpu voltage and change it to 1.75, then check in hardware monitor in bios, it reads a default of 1.5 still. i cant get this thing to load windows. i have a hard drive that works on a intel machine with windows me on it, when i put it on my new machine it fails to boot up. it will give 1 beep as if post is ok, and says memory is ok. i also tried a disk that has been formatted and when it begins to load the files to start the windows installation wizard it freezes. do you think the low voltage of 1.5 is possibly the problem? doesnt a 900 t-bird require 1.75v? i also have a geforce2 gts card, can someone give me some bios settings to get me up and running. is rev. 1.05 a real board, i dont see higher than 1.04 on asus website. thanks dave
