G
Guest
Guest
I'm hoping I have done or missed something really simple here, it's starting to drive me mad.
I just had delivered my,
ASUS A7M226 mobo
AMD TD 1.3 (266Mhz)
1x 128mb PC2100 DDR-SDRAM (Samsung I think)
When I power on the system I am getting no beeps what so ever. The system power light comes on. I have an old Voodoo3 PCI plugged in just to get it all installed but I am getting no display either. I have tested the speaker so I know I am not missing any 'vital' POST beeps.
My concerns are with the modo jumpers. This mobo has jumper free mode, is it ok to use this feature with the components I have? The TD and the DDR? Or maybe I have to use jumper mode?
I took it down to just Processor, Memory, Fdisk, and the Voodoo but it is the same. I tried different sockets for the Voodoo and an older SVGA display and still the same.
Anyone else use this board and processor and had similar problem, or can offer advice on what to try next?
Thanks an advance
Mylex
ASUS A7M226 mobo
AMD TD 1.3 (266Mhz)
Thanks an advance
Mylex
