Using a Xbox 360 with a PC Monitor
bnot
Hey Gang,
I have an Xbox 360, this monitor and I want to use them together. I've been told All I need to buy is a DVI cable which fits the 360 and connect that to the console and my monitor, one problem is that my monitor does not have internal speakers. My sound comes from external speakers plugged into my rear I/O ports. I'm wondering if there was anyway to get those speakers to work the with the Xbox 36?
4
answers
Last reply
More about using xbox monitor
well, 10 years ago I would strongly advise against doing something like this. Today it might be a good choice...
anyways, depending on what you get the dvi adapter for, you might be able to plug in the audio av cables into speakers. I don't know if xbox outputs to all available ports at once. Basically see if you can use component to speakers audio set up and DVI for video transmission. I don't know if it'll work if they feed off different output modes.
I mean if you use HDMI to DVI, then DVI adapter will have to have the cables separately for sound data, otherwise that just outright signal loss and if xbox cannot output to several modes at the same time you are out of luck. -
You need one of these (OPTICAL RCA AUDIO ADAPTER FOR XBOX 360):
http://cgi.ebay.co.uk/HDMI-HD-AV-CABLE-OPTICAL-RCA-AUDIO-ADAPTER-XBOX-360-/290389306035?pt=UK_VideoGames_VideoGameAccessories_VideoGameAccessories_JN&hash=item439c8d2ab3
and maybe one of these (if your speakers are not digital TOSLINK capable) (2x RCA Phono Male to 1x 3.5mm Female Jack Socket Lead):
http://cgi.ebay.co.uk/2x-RCA-Phono-Male-1x-3-5mm-Female-Jack-Socket-Lead-/330462922796?pt=UK_Computing_CablesConnectors_RL&hash=item4cf120082c
HDMI to DVI leads:
http://cgi.ebay.co.uk/NEW-2M-HDMI-DVI-GOLD-PLATED-CABLE-HDTV-1080P-LEAD-/220776526187?pt=UK_Computing_CablesConnectors_RL&hash=item33674e716b
XBOX360 VGA leads if you don't want to use the digital interface:
http://cgi.ebay.co.uk/VGA-HD-AV-CABLE-LEAD-OPTICAL-OUTPUT-XBOX-360-UK-/120697681688?pt=UK_Video_Games_Cables_and_Adaptors&hash=item1c1a247718 -
Just managed to find the model my speakers are.
http://www.ebuyer.com/product/118487
I appreciate the replies so far but Hairystuff you post confuses me a little, exactly which of those cables will I need? Is the first link only for the audio? It appears to be HDMI to the Composite type port on the back of the Xbox and as far as I'm aware my monitor only has DVI/D-Sub. -
Ok basically this lead has a stereo RCA output for your speakers:
But you also need this so that the speakers can be connected to the Audio RCA connectors on the first link:
Related Resources
Console Gaming
Xbox 360
Monitors
Speakers
Video Games
Related Resources
- Xbox 360 connected to monitor but no sound
- Xbox sound problems
- Monitor/Xbox
- Xbox 360 to monitor with HDMI
- XBOX 360 CONNECTION TO PC MONITOR AND SPEAKERS
- Xbox 360 on DVI monitor (22" Samsung)
- XBOX to monitor through VGA
- No sound, xbox 360 on monitor
- Apple adc 22" monitor with xbox 360 help
- Help connecting xbox 360 to DVI monitor
- Using my xbox 360 on an LCD monitor
- Sound-xbox-monitor
- Xbox slim to HDMI monitor?
- Monitor for PC and Xbox 360?
- Using monitor for both my computer and my xbox 360
