Diablo II : Lord of Destruction LAN setting problem
Pixy
12
hello all,
I'm having problems regarding LAN settings in diablo 2: LOD, especially for LAN gaming, is there any solution so that I and my friend can connect, because in Windows 7 do not have IPX / SPX / NetBIOS? so far, I tried to turn off the firewall and antivirus ... and it failed ... please help ...
thanks before
P.S:
-we're not using any router but switch to make a LAN connection and for the LAN setting, is described like this:
my computer:
IP address: 192.168.0.1
Subnet mask : 255.255.255.248
and my friend's laptop:
IP address: 192.168.0.2
Subnet mask : 255.255.255.*
*: I'm sorry, I just forgot the numbers... since we aren't a roommate.. ^^a
Deathsagaxx
118
himachi I think the name is, enabled me and a friend to connect via laptops, since all the other options were bogus, its a complicated game to connect thru lan, and i dont understand why, im not even sure if himachi is still working, but give it a shot
Pixy
12
humm... Hamachi is always messed up my Garena Network before... so I think I won't use it (unless there is no way to make a 7 become capable of LAN Gaming like on XP before...)
Deathsagaxx
118
try establishing a lan connection through ur control panel? and give him the password and such to join it, that was another way we did it, but it took a good 20 minutes to figure it all out
Deathsagaxx
118
if u have windows 7, its control panel>network and internet>network and sharing center and its "set up a new connection or network, from there you'd have to do everything urself, since like I said, it took us awhile to figure it out since we had never needed to use it, cept for diablo lol
