Cable Modem -> hub -> 2 wireless routers Will this work?
Last response: in Wireless Networking
Archived from groups: alt.internet.wireless (More info?)
I'm trying to set up a mixed wireless system. Router 1 will be only a
'g' receiver and router 2 will be only a 'b' receiver. Someone I was
talking to says that the modem will not be able to deal with 2 WAN
connections. All I am trying to do is have a simple setup...no
firewall before the routers, etc. since I will have these capabilities
within the routers.
Anonymous
Wireless Authority
>within the routers.
Won't work unless you have two routeable IP addresses from your ISP.
Each router needs a unique IP address on the WAN side.
However, all is not lost. You can "convert" one of the routers into
an access point by:
1. Ignoring the WAN port
2. disabling the DHCP server.
3. Assigning an IP address to the LAN side of the access point
that is NOT the same as the other router. For example, if
the "g" router is on 192.168.1.1, then the access point
should be on 192.168.1.2.
Then, just plug the LAN port of the "b" access point, into the LAN
port of the "g" router. You may need to build or buy an ethernet
crossover cable to do this.
# Jeff Liebermann 150 Felker St #D Santa Cruz CA 95060
# 831.336.2558 voice http://www.LearnByDestroying.com
# jeffl@comix.santa-cruz.ca.us
# 831.421.6491 digital_pager jeffl@cruzio.com AE6KS
Anonymous
Wireless Authority
Here is my experience, which is not that complicated. But, I had 2 wireless
routers connected lan port to lan port with dhcp off on router 2 and
different ssids on both. I was able to connect gs to router 1 SSID and Bs to
router 2 SSID. This acted as a seemless network. Now, if I took router 1
Lan port and put it into a Wan port on router 2, I had a totally separate
network on different subnets with the same gateway and had Gs on one and Bs
on the other with separate SSIDs
So talk to me..........Am I a disallusionist or just a dreamer.............
"Jeff Liebermann" <jeffl@comix.santa-cruz.ca.us> wrote in message
news:gt9vq0dkrh41sru3bl3slh8g2s4qkr2fje@4ax.com...
> >within the routers.
> an access point by:
Anonymous
Wireless Authority
On Thu, 2 Dec 2004 18:47:58 -0600, "Airhead"
Well, you're also one of them "top posters" that drives me insane.
Actually, that's not a major accomplishment as I was already insane
before you started top posting.
You're not dis-illusioned or dreaming. What you describe works. The
way I described it, using one router and one access point, you get a
single network with two ways to get to it via wireless.
Your scheme is two seperate wireless networks. The first wireless
router, which I arbitrarily call the "g" router, connects to the
internet and uses NAT to assign a network of 192.168.1.xxx to the
wireless clients. The 2nd router, which I'll call the "b" router,
connects its WAN port to the LAN port of the "g" router. The "b"
router will have a WAN side IP address of perhaps 192.168.1.2, and a
LAN side IP block of 192.168.123.xxx. Depending on the netmask on the
WAN side of the "b" router, neither wireless LAN will be able to see
the other. I use this for coffee shops, where I don't want the public
LAN to see the office computahs.
If the netmask were the usual 255.255.255.0, then the wireless clients
on the "b" router will be able to see the wireless clients on the "g"
router, but not the other way around.
>> >within the routers.
>> an access point by:
Related ressources
Anonymous
Wireless Authority
news:9clvq0d6630ugl4u53u11mb44vjiist1de@4ax.com...
wireless
and
and Bs to
router 1
separate
one and Bs
The
the
public
clients
"g"
At first I thought you were giving me a complement of being a "Top
Poster" ,,,like good answers
Then I realized you dont like me posting on the top of messages. Just
for you, because I admire your knowledge, I will post on the bottom or
somewhere in between.
So, I am not a net mask guru, would you explain the net mask
issue....I might not want my wife on her B network seeing my G stuff.
only a
I was
WAN
capabilities
> >> >within the routers.
ISP.
into
> >> an access point by:
LAN
Ah, gotcha. This is then what I'd like to set up...thinking security
all the way.
The 'b' router is my TIVO router...and less secure. I figure I could
set it up so that if anyone got through it, then they'd only get the
TIVO and the 'net.
The 'g' router is for my computers. It has a better firewall and mac
address checking.
Here is what I'd want...two networks 'b' and 'g'. I want to be able
to see the 'b' with the 'g' network, but not necessarily the other way
'round. That way, I could access the 'b' network with my computers
and fiddle with the TIVO...and I don't see any reason why the TIVO
needs to see my computers...I could add the TIVO mac address to the
list if I need to...but why? I'd also want just the router firewall
protecting each network...don't want to have to punch a hole through
two firewalls if I need to...that's why I thought a hub would be
ideal...just a dumb connection to the net.
Suggestions, solutions?
THANKS GUYS...this is the first time I tried to set up a complicated
network.
John
Anonymous
Wireless Authority
On Fri, 3 Dec 2004 06:27:31 -0600, "Airhead"
I never give compliments. See:
http://www.caliburn.nl/topposting.html
for why top posting is bad.
I'm honored, I think.
Ok. Typical two routers in series (double NAT) mess:
LAN #1
WAN===[Router #1]===================[Router #2]=======LAN #2
WAN = xxx.xxx.xxx.xxx WAN = 192.168.1.2
WAN NM = 255.255.255.0 WAN NM = 255.255.255.0
LAN = 192.168.1.1 LAN = 192.168.5.1
IP's = 192.168.1.xxx IP's = 192.168.5.xxx
LAN NM = 255.255.255.0 LN NM = 255.255.255.0
Computers on LAN #1 cannot see any computers on LAN #2.
Computers on LAN #2 can see all computers on LAN #1
Both LAN #1 and LAN #2 can see the internet. The "5" in the
192.168.5.xxx IP block is arbitrary.
If you do NOT want any of the LAN #2 computers to see the computers on
LAN #1, you change the subnet mask on WAN port Netmask on Router #2 so
that it only will "see" Router #1. That would look like his:
WAN NM = 255.255.255.0 WAN NM = 255.255.255.252 <===
Digging out my handy subnetmask calculator:
http://www.wildpackets.com/support/downloads
This will allow only two IP address (192.168.1.1 and .2) to be seen by
the WAN port of Router #2 (in addition to the broadcast address of
192.168.1.3). Note that 192.168.1.2 is the WAN IP address of Router
#2 so there is really only one useable IP address. I like to have a
few more IP's to install print servers and shared devices, so I tend
to use 255.255.255.248, which allows 5 useable IP's.
Jeff Liebermann jeffl@comix.santa-cruz.ca.us
150 Felker St #D http://www.LearnByDestroying.com
Santa Cruz CA 95060 AE6KS 831-336-2558
Anonymous
Wireless Authority
>all the way.
See my previous posting, where I posted a proposed IP layout. The
only trick is the netmask on the WAN side IP port of the 2nd router
should be 255.255.255.252 or 255.255.255.248.
>TIVO and the 'net.
What's a TIVO router?
>address checking.
Yeah. This is rediculous. There's no reason to make life complicated
with double NAT and two routers. It all can be done the way I
originally proposed by turning one of the routers into an access point
(disable the router features) and make it all one big LAN. There's no
security advantage to a double NAT system as any attack is going to
come through the wireless side (LAN) and therefore bypasses all the
protection of the router. The "secure" network is the one connected
to the 2nd router and it's going to have some fun dealing with
services that require holes in the firewall. Keep it simple.
However, if internal security is important (i.e. keeping the kids and
neighbors out of parts of the network) you might was well go for the
double NAT method.
Anonymous
Wireless Authority
Thanks, now I have more etiquette
Just
or
stuff.
> LAN #1
on
so
Thanks for the explanation. It is appreciated! Plus I understand it
which is hard for an Airhead.
by
Also thanks for the handy calculator.
As I am sure you know, a TIVO is a DVR for satelite, cable or OTA
television. My old 'b' router's new purpose in life is to connect the
TIVOs to the internet to recieve the Guide information, hense the name
'tivo router'.
Ask the community
