I was playing with my mobo (a MSI turbo-r) a couple of days ago and i accidently left the CMOS jumper to clear data and i boot the PC. The pc wouldnt post (i was oc and i thought it was because of that). I switched off and then tried to boot again but no bleeps, no fans, no lights. It is like i have it unplugged. The manual said that if i powered the pc with the CMOS at clear it would damage my mobo. Damaged mobos cause everything to die? Wouldnt some fans that are connected to the power and not the mobo work? I have an extra suppler at home, should i try to see if the old is is burned or it is a waste of time?
Also if i try to replace it as a defective mobo the techs will find that i destroyed it or they will see nothing and think its indeed a defective piece?
Palpatine
Palpatine
