G
Guest
Guest
I just bought the following new components.
Iwill KA266-R mobo
Athlon 1.33 cpu
Crucial 256 DDR ram (3 sticks)
WD 40 gig HD
Sony RW CD
Enermax 430W PS
Lian Li 60 case
The follwing items I'm reusing from a previous system.
Elsa Gloria XL graphics card
Logitech 3 button mouse
Generic keyboard
Generic 1.44 floppy
I assembled all the above listed items. Left the mobo settings at default and turned the power on. The LED's light up properly on the case, the fans work on the case, the CD works (will open and close) and the hard drive starts to spin up. In my previous post I said that the hard drive stops. My mistake. The hard drive continues to spin. The system will not post. That's what I meant by "nothing".
I've built numerous systems over the years but have never tried to overclock any of them. One suggestion to my previous post was to set the clock multiplier for a slower cpu. I don't see anything in Iwill mobo user guide on which settings are for specific cpu's.
The graphics card works fine in my other system. I hooked the hard drive up to the other system and loaded NT after I could not get this new system to post. I have no way to test the mobo, ram or cpu in another system.
I get NO beep codes while trying to start the system.
I hope I provided enough detail this time.
TIA
Iwill KA266-R mobo
Athlon 1.33 cpu
WD 40 gig HD
Sony RW CD
Enermax 430W PS
Lian Li 60 case
Generic keyboard
Generic 1.44 floppy
TIA
