Tom's Hardware > Forum > Wireless Networking > Wireless General Discussions > does encryption cause intermittent connection?
Forum Wireless Networking : Wireless General Discussions - does encryption cause intermittent connection?
Archived from groups: alt.internet.wireless (More info?)
Hi all:
I have two Netgear MR814 V1 and one USRobotics URS8054. The two Netgear
routers never worked well with encryption. The connections between the
router and the laptop keeps going on and off, and is so frustrating. if i
turn encryption off, it works fine.
The USRobotics used to work well with encryption, but one day, it started
doing the same thing as with the Netgear (intermittent connection). so i
removed the encryption and now it works well.
The question is: is this a common problem with most routers?
Is there anything i can do to fix this problem?
If i can't fix the problem, is there any risk of using online banking or
providing credit card information over an unencrypted wireless connection
(even though the page accessed is https)?
the only security measure takes in limiting access by mac address (is this
better than nothing?)
thanks for any help.
hilz
Sponsored Links
hilz wrote:
>Hi all:
>hilz
I haven't used routers with built in WiFi, but at one site I'm using a
netgear access point with WEP encryption and at another site a linksys
access point using WPA encryption. No porblems.
An intermittent connection probably has some other cause -- weak signal,
etc.
Reply to Anonymous
When you say "encryption", do you mean WEP64, WEP128, WPA, or
something else? I've had problems with WPA in certain circumstances
that go away when reverting to WEP128.
The HTTPS will secure your data, but you really need to encrypt the
link.
Yes, it's better than nothing, but not a lot. Update the firmware on
your router, change the channel, turn off interfering devices, etc...
Reply to Anonymous
If your client computahs are running Windoze XP, please turn OFF the
802.1x authentication and the disconnects should cease.
SSL browser security isn't the greatest, but it's generally good
enough to prevent sniffing. However, all your other traffic will be
sniffable without encryption, leaving you open to identity theft,
password sniffing, and general havoc on your LAN. MAC security is
incredibly easy to circumvent is only useful to prevent "accidental"
connections for random client radios. I would make the effort to fix
WEP.
Incidentally, I have two MR814v1 routers at various customers running
WEP 128 without incident.
# Jeff Liebermann 150 Felker St #D Santa Cruz CA 95060
# 831.336.2558 voice http://www.LearnByDestroying.com
# jeffl@comix.santa-cruz.ca.us
# 831.421.6491 digital_pager jeffl@cruzio.com AE6KS
Reply to Anonymous
There are 980 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
