G
Guest
Guest
Well I recently decided to dive into the wonderful world up Upgrading Your Motherboard <ominous muzak> I purchased a shiny new K7VZA based on it's wonderful review on Tom's and got a shiny new 1.2 Ghz TBird with it. Now here is the funny thing I learned - if your bus speed is set at 100 mhz instead of 133 Mhz the CPU will only run at 900mhz. The solution? Crank up the bus speed to 133mhz like it is supposed to be. Well...not so easy. I found a place in the BIOs to change the buss speed but it seems the only choice I have is for overclocking it to 101mhz - 112mhz. No 133 Mhz. Any clue what I'm doing wrong here?
~ DurandalX
P.S. I've got my Ram set at 133 in the BIOs and I do have PC133 Ram installed.
~ DurandalX
