A7M266 Shutdown problem
Forum Motherboards & Memory : General Motherboard - A7M266 Shutdown problem
Like it says my PC won't shutdown, it restarts fine, but everytime I go to shutdown it goes to a blank screen with LED lights and fans on. When I flip the power bar off then restart it Windows ME doesn't give me the "make sure to shutdown" speech. So windows does shutdown, the mobo just never clicks the power off. It however has shutdown 2 or 3 times fine so that means the wiring is right, right? The other PC's I've built had this problem for a week or two but it went away permenantly after that.
Any ideas?
I AM Canadian.
Sponsored Links
Did ACPI somehow become disabled in the BIOS?
Probably not, but it doesn't hurt to check...
Reply to jlanka
Might be the old Win 98SE/Me shutdown bug.
The latest device drivers for ALL your hardware will fix this problem if that's what it is.
Reply to ozmol
I have the same problem, sometimes it power off other times it doesn't. I then hit the power switch. I can live with it.
A Child of the King,
Kinnie
Reply to Kinnie_III
Tom's Hardware > Forum > Motherboards & Memory > General Motherboard > A7M266 Shutdown problem
There are 1186 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
