Tom's Hardware > Forum > Wireless Networking > Wireless General Discussions > Best Antenna To Use To Extend Wireless Range As Far as Pos..
Forum Wireless Networking : Wireless General Discussions - Best Antenna To Use To Extend Wireless Range As Far as Pos..
Archived from groups: alt.internet.wireless (More info?)
Hi Everyone,
Ok basically what I want to do is use 1 Acess Point and entend the
range of coverage as far as possible, I have seen all the 12dbi and
15dbi antenna's around on the net, but I am not sure you can use these
and have a client connect to that antenna from their regular wireless
ard built into their laptop etc.
If I cannot use one of these, what is the higest dbi antenna I can
use, and whats the best way to place it, as high up on a roof as
possible etc?
Any help is really apprecaited.
Sponsored Links
On 5 Dec 2004 05:27:32 -0800, squarebox@squarebox.com.au (Joshua
Anderson) wrote:
>Hi Everyone,
>possible etc?
You probably need to state the limits of you budget. With
unlimited $$$ you can get the "best", other wise you will need to
settle for less..
Reply to Anonymous
Joshua Anderson wrote:
> Hi Everyone,
> possible etc?
http://www.oreillynet.com/pub/wlg/4045
Reply to Roger
In one direction (point to point), in a sector, or in all directions
(omni)?
That depends where the client is located relative to the antenna. If
directly below the antenna, there is enough leakage and sidelobes to
make a tolerable connection. However, it's not reliable and subject
to extreme sensitivity to the client radios exact location. You would
be better off with a 2nd radio acting as an access point to take care
of the inside WLAN. Use a different channel (1, 6, or 11) to avoid
mutual interference.
>possible etc?
How big is your roof?
http://www.w1ghz.cx/antbook/chap4.pdf
http://www.ultimatecharger.com/dish.html
Methinks a pedestal mount ham EME dish might be a bit extreme and far
too heavy. My guess is a 2 meter dish is about as large as what could
be accomidated on a roof. At 2.4GHz, with an optimized feed, that
will yield a gain of about 30dBi gain.
gain(dB) = 20 log (7.4 * 2.4 * dia)
where
dia = diameter in meters
2.4 = frequency in GHz
For a point to point link, you'll need to reduce your xmit power to
+21dBm to be FCC legal.
Jeff Liebermann jeffl@comix.santa-cruz.ca.us
150 Felker St #D http://www.LearnByDestroying.com
Santa Cruz CA 95060 AE6KS 831-336-2558
Reply to Anonymous
Hi,
I am not really interested in setting any world records, if it went a
couple of miles I would be happy, my main question is really about the
dbi of the antennas, can I use any antenna and have wireless clients
connect using their standard wireless card, or is there a max dbi gain
I can use before it all goes haywire?
Rôgêr <abuse@your.isp.com> wrote in message news:<xcSdnWy3c6iwxy7cRVn-tQ@pghconnect.com>...
> > Hi Everyone,
> > possible etc?
Reply to Anonymous
On 5 Dec 2004 15:24:12 -0800, squarebox@squarebox.com.au (Joshua
Anderson) wrote:
>Hi,
An important point is where are your clients located? Are they
spread evenly around your site in all directions, or are they all
located in a specific area where a directional antenna would be
appropriate?
Reply to Anonymous
Hi Jeff,
Thanks for your response.
It needs to be omni, I need to catch as much area as possible, 360
degrees if possible.
If I cannot get access directly under the antenna thats fine I will
use another AP for that area, what I really am looking for is extended
coverage in the wider vacinity.
Roof wise it will be about the standard house size, with the antenna
mounted at the highest point obviously.
I assume a dish is no good for omni, I was looking at the Dlink 15dbi
antenna:
http://www.dlink.com/products/?sec=&pid=289
This looks ok to me, price is reasonable too, is this something I
could use?
Thanks again for your help
Jeff Liebermann <jeffl@comix.santa-cruz.ca.us> wrote in message news:<r1u6r0dt0qdnhrnbm5ea5b2ovstjessfss@4ax.com>...
> (omni)?
> >possible etc?
> where
Reply to Anonymous
There are 525 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
