Yes No
Ads
Tom's Hardware > Forum > Video Games > PC Gaming > Yet Another BC2 Problem
Forum Video Games : PC Gaming Yet Another BC2 Problem
So i've made a couple threads about this problem alone, First i though it was a Realtek onboard audio problem where is was conflicting with, but yesterday i bought a headset (USB so it should act like a soundcard, as far as i know) but my CTD still happen so it wasn't a realtek problem well then what could it be?
Also when ever it CTD my desktop always goes to (i believe 640x480 resolution) and the colours get all messed up
http://i53.tinypic.com/140gmqh.jpg
(I don't know how good the picture is)
Any Help would be appreciated I would love to be able to play this game.
Oh ya! sometimes when it CTD it freezes for a second and my sound loops
Thank you
-Mithness
Reply to Mithness
Hi
What are yor full specs, CPU / GPU / RAM MBOARD/WIN VERSION ECT and I guess you mena BF bad company 2 ??
Reply to peachy_29
Oh yea forgot to add those my bad
AMD Athlon 64 x2 5600+ OCed to 3.1ghz
ATI Radeon HD 4350 (Crap I know but i can play BC2 Fine with it, other than crashes)
2Gb DDR2 800mhz
160GB harddrive (Came with PC)
500GB Western digital
500Watt Thermaltake TR2 PSU
Windows XP Professional SP3
Mobo is a modified Foxconn mobo for this ACER computer
And yes I ment Battlefield Bad Company 2
Thank you for the reply Peachy
Reply to Mithness
for some reason your settings are being switched from 32bit to 16bit in the display settings. this normally means a bad driver. so either your gfx card is over heating causing your driver to quit and not restart. or you have some other issue with your gfx.
run some intensive tests like furmark and see if that causes the same issue, while you run gpu-z along side it to measure temps.
i think i would bet on bad memory on the gfx card...
Message edited by HEXiT on 06-20-2011 at 08:04:26 AM
------------------------------ |i7 920 D0@3.6 |CNPS10 flex |ex58-ud5 |6Gig 1333 C7 |HD 5870
|G11 keyboard|X-fi Xtreme |G930 |3x1tb SpinPoint f3's raid 0 |thermaltake tp 850watt |antec 902
|Rat 7 contagion |Razer Destructor mat |bamboo pen'N'touch | 3d pro stick |nitro wheel |360 pad
Reply to HEXiT
Okay, I will try, but this doesn't happen to any other game so hmm.
and my drivers are 11.4
Also is Furmark free? or is it something you have to buy?
Reply to Mithness
I believe Furmark is free, a quick google search of Furmark should do the trick.
Reply to easymark26
I Ran Furmark at 1280x720 for 5 Minutes
IDLE: 60C
MIN: 62C
AVG: 70.9C
MAX:79
As far as i know these are repectable Temperatures? Or am I wrong? also my ambient house temperature right now is about 25-28 Degrees (No AC on)
*Edit the 5-10 minute crashes were my realtek audio, I had to actually disable it in the device manger. So it stopped crashing i was playing a nice online game on cold war (i think or something) when all of a sudden BOOOMMM my PC just turns off. Which would this be most likely? My CPU? Or my GPU, My GPU is passivly cooled and i'm thinking this is the leading cause if this is it, do you recommend any thing to fix this?
Message edited by Mithness on 06-21-2011 at 04:25:10 AM
Reply to Mithness
There are 1991 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Diablo 3
By DM186, 1 hour ago:
That kinda sound normal. When I play Shogun 2 total war. When I am on the campain map I...
Best offers
Top experts
