G
Guest
Guest
Hello,
I have just assembled a computer on the cheap, and am a bit confused. Set up at the moment is:
900 MHz Thunderbird
Gigabyte GA71xe4
128mb and a Creative TNT2 Ultra 32Mb.
Lg 52x cd and WD 30gb7200 hd.
On the board there are settings to change the bus speed (I think), the default is 100MHz. Does anybody know if I need to change this, as the system often hangs and is generally a bit dodgy? Also I think my cd is too fast to install win98.I have tried and failed many times.Any help would be greatly appreciated!
900 MHz Thunderbird
Gigabyte GA71xe4
