G
Guest
Guest
I've just finishid builing my own pc. (Soltek SL75drv, Athlon 1200, 256ddr, 40 gb IBM, Inno3d Geforce 2GTS, 52X Sony cd-rom, floppy etc). The computer boots ok and find every item. The problem is after the "Verifying DMI Pool data..... Update succes". The message
"Boot from ATAPI-CDROM:"
DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER.
I have inserted win98 start diskette, win98 cdrom, the cdrom delivered with the mainboard but everytime I press enter the: "Boot from ATAPI-CDROM:
DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER."
message appears. I really need help here, I have checked all cables, changed settings in BIOS, changed hardware (floppy,cables,cdrom). What boot disk does it really want? I just need to get to the prompt so I can install win98 or win2k.
Help is appriciated! =)
