Archived from groups: alt.internet.wireless (More info?)
I have a Sony NVR23 laptop with a D-Link DWL-650+ running Windows XP
Home. It is connecting to a D-Link AP DWL-900+. The computer crashes
about twice daily with the message "DRIVER IRQL_NOT_LESS_OR_EQUAL...."
and indicates the problem is in airplus.sys.
I want to get rid of this D-Link wireless hardware and get something
more reliable. Can someone recommend a wireless solution that they know
works reliably in a Sony VAIO laptop ? Thanks.
We had good luck with Linksys PCMCIA cards in our PCG-V505 series
laptops, FWIW.
Me, and few my colegas, are using Belkin Pre-N (diffrenet types of VAIO's,
mine is PCG-GRT390). No blue screen saw :-)
"brainiac" <brainiac@visi.com> wrote in message
news:41b59604$0$11064$a1866201@visi.com...
Sounds like you either some resource conflicts in your laptop or maybe
you need an updated driver.
Check what driver version the card is using and check dlink for
updated drivers.
know
In article <41b5dfc0$0$798$2c56edd9@news.cablerocket.com>,
>updated drivers.
I have been updating the drivers for over two years now. They even
changed the name to "airplus.sys" about a year and a half ago. After
researching the problem I found that it is common for vaio's to bluescreen
with the DWL-650+. The problem is that D-Link wrote a driver that isn't
compatible with vaio's.
