G
Guest
Guest
Hi Everyone,
This is my first post here, I hope it's not off topic or
anything.
I just bought myself an Athlon 1.2Ghz(266) AXIA chip and
a ABIT KT7A mobo, 40gig seagate drive, new case.. etc.
However, I CAN NOT get it to run on Windows 2000 with
a bus speed of 133/33 and a multiple of 9!
If I have it at this speed and the system boots, If I can
get Sandra 2001 loaded I can run CPU/Memory test for
hours, yet the first time there's heavy disk (like
booting or anything else) it freezes the machine.
This is very confusing to me, as if I wind the clock
speed back to 100/33 (multipler of 12) the system runs
100% stable but a fair bit slower.
Anyone else had this problem? It seems that when running at the full speed any disk activity can cause the system to fail (freeze). I've run out of wits on this one..
Is it the CPU? Memory? Motherboard or the Hard Disk?
Where should I look? I'd like to eliminate possible
causes of the problem before going back to the PC shop
and asking them to fix it..
Any help appreciated..
Here is the system spec.
1.. 1.2Ghz Athlon (266Mhz) AXIA (no idea what AXIA means)
2.. ABIT KT7A Motherboard (brand new)
3.. 256 meg memory (SD-RAM NCP?)
4.. Seagate Barracuda ATA III 7200rpm 40gig
5.. Sound Blaster Live! 5.1 Digital etc
6.. Pioneer 116 16x dvd
Other notes:
SiSoft Sandra gives the drive a rating of 25500 while
running in 100/33 Mhz bus speed. Yet when the bus speed
is at 133/33 Mhz the rating drops to 11500 (that's when
it 'can' complete without freezing).
I'm no hardware expert, but something here seems a bit
odd. I'm running this rig at 100/33 right now.. Should
I just accept this as bad luck?
-Westie
anything.
Other notes:
-Westie
