Archived from groups: alt.internet.wireless (More info?)
My internet connection was painfully slow through Linksys router.
Bypassed and went through cable modem and Roadruner tech support
reported no dropped data and a 1.6MB/s throughput. So router became
suspect. I flashed the latest firmware update to it, cleaned out some
popups and speed now is tolerable, BUT....
Checked throughput using cnet's online utility and 2wire.com, and
they show 400KB/s. Linksys's tech support said those online tests are
not very accurate and considered my problem fixed since speed seemed
reasonable after updating router firmware and getting rid of popups.
Question though is: Is something still wrong with router or
computer causing a tested 400KB/s throughput which is 1/4 the
throughput when connected directly through the cable modem ? Shouldn't
it be showing something closer to 1.6MB ?
I know the ISP is the bottleneck when getting out to the internet
and not the router. But if the Linksys router (802.11B) is funky and
causing the slow throughput, would it be worth it for me to try the new
Netgear 802.11G router I just bought (and was going to take back if
flashing the Linksys fixed the problem)? Or could I expect it also to
just show 400 KB/s even though its a "G" capable of 54 MB/s, e.g. are
the internet speed tests off by that much and I'm really getting close
to 1.6MB/s through the LInksys ?
Any opinions or wildass guesses would be helpful. Thanks.
Bob
<bcarwell@us.ibm.com> wrote in message
news:1102652979.522493.230830@c13g2000cwb.googlegroups.com...
some
are
Shouldn't
and
new
to
are
close
> Bob
Have you ran the same 2wire test with and without the router?
This would give you a better picture of what the router is doing.
>they show 400KB/s.
I'll assume that the 1.6MB/s is really 1.6Mbits/sec.
However, it's not clear if your 400KB/s is really 400KBits/sec or
400KBytes/sec. If it's bits, then you have some kind of major speed
problem. If it's Bytes, then that equals 3.2Mbits/sec which is what
you should normally be getting from a cable modem connection.
Most of the online speed tests vary in performance depending upon how
many intermediate systems are between the test site and your cable
modem. The best test is usually the one supplied by your cable modem
vendor on their locally connected web pile. Who's your cable ISP?
Jeff Liebermann jeffl@comix.santa-cruz.ca.us
150 Felker St #D http://www.LearnByDestroying.com Santa Cruz CA 95060 AE6KS 831-336-2558
some
> >they show 400KB/s.
Shouldn't
> 150 Felker St #D http://www.LearnByDestroying.com > Santa Cruz CA 95060 AE6KS 831-336-2558
Thanks for responding. I think it megabytes and kilobytes, so yes,
it looked like the router was slowing things down. I ran test again on
different machine through CNET and it shows 1.4MB/s, so I think it is
the other machine (adware, spyware, etc.). On the different machine,
internet speed is fine, so I think flashing/updating the firmware on
the router did the trick and I'm just dealing with an older computer I
need to cleanup. Thanks for the help. Seems like I'm okay again...
(BTW, ISP is Road Runner).
Bob
First i used the BSNL broad band only. While i faced some problems on it & the service provider was not responding & never solved my problem properly. SO i switch over to another service provider. Recently i checked the speed test from http://www.ip-details.com/internet-speed-test/
