G
Guest
Guest
Hello all,
This post is similar to previous posts, but I just want to get confirmation on what I should do.
I bought an Asus A7V133, Athlon 1.2 266FSB, nVidia GeForce2 MX, and a case, and cannibalized hard drives, etc. from my old computer. I brought up my system, and Windows ME happily started finding new hardware, and finally got me to a stable state, although I still have to install a driver for the AGP card. When I booted after the stable state, I saw my bios reported 900 MHz: 9.0 mult and 100Mhz frequency. I decided to fix it, because I bought a 1.2. I went into bios, set mult to 12.0 and left freqency at 100Mhz, rebooted, and saw that bios reported a 1200 Mhz. Good, so far. I then went in and tried to set the frequency to 133 Mhz, after all, it's a 266 FSB and this should work, right? I rebooted, now nothing happens. I can't even turn the thing off except with the power supply switch (just like the guy several posts earlier).
My questions are:
1) Have I burned up my chip?
2) Should I take out the battery and let CMOS reset, or is there another (better) way?
3) Has anyone seen all of the hair I have pulled out of my head?
Thanks for your replies,
Lorin Johnson
<P ID="edit"><FONT SIZE=-1><EM>Edited by lorinj on 06/21/01 01:04 PM.</EM></FONT></P>
My questions are:
Lorin Johnson
