If you have checked the connections and they are as they should be, I suggest you recheck and follow the manual illustration carefully.
Failing that, take back where you purchased it and get it replaced.
On the Edge of Extremity
Microsoft Registered OEM,DSP,MCP
Custom Building of PC`s.
