Tom's Hardware > Forum > Wireless Networking > Wireless General Discussions > Speed problem for wireless network?
Archived from groups: alt.internet.wireless (More info?)
Hi,
My wireless network is running 802.11B on one laptop. Everything seems OK
until I start using the 5Ghz cordless phone. It still working but very slow
and even I put it right beside the SMC wireless router, the network
connection show it is connected at 1 Mbps.
Does the 5Ghz phone will affect the 802.11B ( which suppose is 2.4Ghz)
wireless network?
Thanks!
Sponsored Links
On Fri, 10 Dec 2004 14:26:41 -0500, "Ray" <mapperkids@yahoo.com>
>wireless network?
Any particular reason for not disclosing the model of cordless phone
or SMC router?
Several 5GHz cordless phones have the base unit transmit on 2.4GHz.
Such cross band devices also exist with 2.4/900MHz such as the
Panasonic Giga-Range. Your SMC is probably getting trashed only by
the 2.4Ghz from the base unit. If it's a frequency hopping spread
spectrum (FHSS) base, then moving to a different channel on the SMC
will not help.
Jeff Liebermann jeffl@comix.santa-cruz.ca.us
150 Felker St #D http://www.LearnByDestroying.com
Santa Cruz CA 95060 AE6KS 831-336-2558
Reply to Anonymous
On Fri, 10 Dec 2004 11:46:06 -0800, Jeff Liebermann
>>wireless network?
>or SMC router?
>will not help.
Well, I screwed up slightly.
The Panasonic GigaRange Extreme base unit transits on 2.4Ghz and
receives on 900MHz.
Phones that use Atmel dualband chipsets have the base unit transmits
on 5.6GHz and receives on 2.4GHz. Therefore, it's the handsets that
are causing the 2.4GHz interference, not the base unit as I claimed.
http://www.eeproductcenter.com/pri [...] D=49901614
Reply to Anonymous
- 0 +
The cordless phone that I'm using is UNIDEN TCX800 and I can't find anywhere
in the spec saying about 2.4Ghz. All it say just 5.8Ghz handset.
Does anyone use this phone with 802.11B wireless network?
Thanks!
"Jeff Liebermann" <jeffl@comix.santa-cruz.ca.us> wrote in message
news:2o8mr09huq50qr8uivtg79l287kltu2pn6@4ax.com...
OK
slow
> >>wireless network?
> >or SMC router?
> >will not help.
> receives on 900MHz.
Reply to ray
On Sat, 11 Dec 2004 18:38:53 -0500, "Ray" <mapperkids@yahoo.com>
Skimming through the docs, it appears that the TCX800 is 5.8GHz only.
In theory, that should not interfere with your 802.11b/g network in
any manner, unless they really are using 2.4GHz in the cordless phone.
Could you supply the FCC ID number from the serial number tag so I can
look it up in the type certification test results for the type of
radio used? It will probably be AMW-xxxxxxxx or AES-xxxxxxxxx.
Reply to Anonymous
There are 709 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 TH won the Freshman badge
  • 01:00 exploresalot won the Freshman badge
  • 01:00 mlg779 won the Freshman badge
  • 05:31 Mysteic won the Sophmore badge
  • 01:00 listerd won the Freshman badge
  • 01:00 stephen98146 won the Uniformed badge
  • 01:00 LANKO1982 won the Uniformed badge
  • 01:00 sitec won the Uniformed badge
  • 01:00 iiraymoii won the Freshman badge
  • 03:27 cjl won the CPUs badge
