G
Guest
Guest
Here's my specs:
Asus A7A266 bios ver. 1004(newest)
Athlon 1.4 gig and
Athlon 1.33 gig Cooler Master hsf
256 ddram
40 gig ibm hardrive
geforce1 ddr
300 watt power supply
My computer is running fine, until it overheats and freezes.
At idle speed it runs about 138F-140F but gets around 148F-150F when playing games.
The vcore is running at 1.85 volts (on both processors) but should be at 1.75.
I tried changing the voltage manually in the bios, but it wont budge from 1.85. Also tried changing VID jumper.
Could this increase in voltage cause my processor to heat up more than it should? Happens with both processors(neither overclocked). Definitely not the processors' fault. Should i get a replacement board?
This is the first computer I built. Am I doing anything wrong?
Athlon 1.4 gig and
256 ddram
40 gig ibm hardrive
geforce1 ddr
