Tom's Hardware > Forum > Motherboards & Memory > General Motherboard > Help with GA-7IXE4 CPU SPEED
Forum Motherboards & Memory : General Motherboard - Help with GA-7IXE4 CPU SPEED
Hi peeps i have just brought a Gigabyte GA-7IXE4 motherboard and an AMD 1.2ghz Cpu When i fitted this together the highest speed i can run this at is 1035mhz with the jumper set at max (115mhz fsb) can anyone help me to get this running at the right speed.
Cheers Rodders
Sponsored Links
Sorry dude, I checked out their website and it looks like your out of luck.
Your board supports 100/200mhz FSB NOT 133/266mhz FSB. But like you said, there are jumper settings that let you choose 90*/95*/100/105*/110*/115* MHz FSB...and nothing higher. So you can't run your 'C' processor at the right speed unless there is an option that lets you choose the multiplier. You can set it to 10.5 and that will give you 1,207mhz. My personal suggestion to you is either return your CPU and get a 1.2ghz 'B' CPU with 100/200mhz FSB or buy a new motherboard that supports 133/266mhz FSB. (I'd return the motherboard and get a new one).
<font color=blue>Your mouse moved. WINDOWS NT must restart for changes to take affect. Restart Now?[OK]</font color=blue>
Reply to Stick_e_Mouse
There are 1015 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
