G
Guest
Guest
I work in a small computer store. Recently we got a lot of problems with ASUS A7A266 motherboard. The biggest problem is OVERHEAT!!!
We tried almost 10 different system boards with exactly same cooling system, same CPU and Case. All the boards are working fine with 1.2Ghz or higher CPUs like 1.33Ghz or 1.4Ghz.With ASUS A7A266, there is just no way we can cool the system down. It will reach over 65 degrees or higher in about 2 minutes and the system will become unstable or just stop working. We called the ASUS technical support; their technicians insist that our system is not properly cooled. That ‘s ridiculous!!! Why other system works fine?
I just want to know if anybody has the similar problem. This problem will happen on most A7A266 motherboards with few exceptions. I suspect there must be some design flaws in A7A266 or the Ali Magik chipset.
I need some help here, can anybody tell me if there is some solutions for this? Also this motherboard is just so unreliable, we got 2 defects in about every 10 (not including the overheat ones).
ANY SUGGESTIONS ARE HIGHLY APPRECIATE!!!! Please help!
