Solved
WoW graphics problems(help)
Last response: in Video Games
I have already tried WoW technical forums, not getting any replies.
So a couple days ago I had a problem with default raid frames, ended up being sent to the technical guys in-game and he let me know that if I run as admin it should fix.
It did fix it, however now I get this, as you can see there is a nice colorful box on the lower right side and odd pixelation on the upper left side of screen.
This is with cache/interface/WTF folder deleted as well
http://imageshack.us/f/684/wowscrnshot081511180246.jpg/
...When I dont run as admin that problem goes away, but the default raid fram problem comes back.
the problem was that when a raid formed only the outline of the raid frame showed and I couldn't hide it and had to /reload ui.. And whenever going through any loading screen - meaning whenever I died it would come back up forcing me to reload ui all night long.
System Information
Time of this report: 8/15/2011, 18:10:45
Machine name: STEVEN-PC
Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_rtm.101119-1850)
Language: English (Regional Setting: English)
System Manufacturer: MSI
System Model: MS-7522
BIOS: Default System BIOS
Processor: Intel(R) Core(TM) i7 CPU 960 @ 3.20GHz (8 CPUs), ~3.2GHz
Memory: 12288MB RAM
Available OS Memory: 12280MB RAM
Page File: 5330MB used, 19225MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: 96 DPI (100 percent)
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 32bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Sound Tab 3: No problems found.
Sound Tab 4: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce GTX 580
Manufacturer: NVIDIA
Chip type: GeForce GTX 580
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_1080&SUBSYS_15823842&REV_A1
Display Memory: 4063 MB
Dedicated Memory: 1503 MB
Shared Memory: 2559 MB
Current Mode: 1920 x 1080 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: ASUS VH238
Monitor Id: ACI23F9
Native Mode: 1920 x 1080(p) (60.000Hz)
Output Type: HDMI
Driver Name: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
Driver File Version: 8.17.0012.8026 (English)
Driver Version: 8.17.12.8026
DDI Version: 11
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 8/3/2011 06:50:00, 15064168 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B71E3E-53C0-11CF-A844-8E351FC2C535}
Vendor ID: 0x10DE
Device ID: 0x1080
SubSys ID: 0x15823842
Revision ID: 0x00A1
Driver Strong Name: oem8.inf:NVIDIA_SetA_Devices.NTamd64.6.1:Section028:8.17.12.8026:p ci\ven_10de&dev_1080
Rank Of Driver: 00E62001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_C ModeWMV9_C
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
D3D9 Overlay: Supported
DXVA-HD: Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Description: Speakers (Realtek High Definition Audio)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0889&SUBSYS_14627522&REV_1000
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: RTKVHD64.sys
Driver Version: 6.00.0001.6316 (English)
WHQL Logo'd: Yes
Date and Size: 2/24/2011 18:21:10, 2753512 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Basic
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Description: Realtek Digital Output (Realtek High Definition Audio)
Default Sound Playback: No
Default Voice Playback: No
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: Yes
Other Files:
Cap Flags: 0xF1F
HW Memory: 0
Description: Speakers (3- Tt eSPORTS Challenger Ultimate gaming keyboard)
Hardware ID: USB\VID_04F2&PID_0978&REV_0145&MI_01
Manufacturer ID: 65535
Product ID: 65535
Type: WDM
Driver Name: USBAUDIO.sys
Driver Version: 6.01.7600.16385 (English)
WHQL Logo'd: Yes
Date and Size: 7/13/2009 19:06:32, 109568 bytes
Other Files:
Driver Provider: Microsoft
Cap Flags: 0xF1F
HW Memory: 0
Description: ASUS VH238-1 (NVIDIA High Definition Audio)
Hardware ID: HDAUDIO\FUNC_01&VEN_10DE&DEV_0018&SUBSYS_10DE0101&REV_1001
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: nvhda64v.sys
Driver Version: 1.02.0023.0003 (English)
WHQL Logo'd: Yes
Date and Size: 5/25/2011 01:09:17, 174184 bytes
Other Files:
Driver Provider: NVIDIA Corporation
Cap Flags: 0xF1F
HW Memory: 0
Sound Capture Devices
Description: Microphone (Realtek High Definition Audio)
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x1
Format Flags: 0xFFFFF
Description: Microphone (3- Tt eSPORTS Challenger Ultimate gaming keyboard)
Default Sound Capture: No
Default Voice Capture: No
Cap Flags: 0x1
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: Tt eSPORTS Challenger Ultimate gaming keyboard
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x04F2, 0x0978
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x3A37
| Matching Device ID: usb\root_hub
| Service: usbhub
Gameport Devices
PS/2 Devices
+ HID Keyboard Device
| Matching Device ID: hid_device_system_keyboard
| Service: kbdhid
+ Razer Naga
| Vendor/Product ID: 0x1532, 0x0015
| Matching Device ID: hid\vid_1532&pid_0015&mi_01
| Upper Filters: RzSynapse
| Service: kbdhid
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
+ Razer Naga
| Matching Device ID: hid\vid_1532&pid_0015&mi_00
| Service: mouhid
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 72.9 GB
Total Space: 122.1 GB
File System: NTFS
Model: C300-CTFDDAC128MAG ATA Device
Drive: E:
Free Space: 415.1 GB
Total Space: 476.9 GB
File System: NTFS
Model: WDC WD5002AALX-00J37A0 ATA Device
Drive: F:
Free Space: 815.6 GB
Total Space: 953.8 GB
File System: NTFS
Model: WDC WD1002FAEX-00Z3A0 ATA Device
Drive: D:
Model: HL-DT-ST BD-RE WH10LS30 ATA Device
Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7600.16385 (English), , 0 bytes
System Devices
Name: Intel(R) ICH10 Family PCI Express Root Port 6 - 3A4A
Device ID: PCI\VEN_8086&DEV_3A4A&SUBSYS_75221462&REV_00\3&11583659&0&E5
Driver: n/a
Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A38
Device ID: PCI\VEN_8086&DEV_3A38&SUBSYS_75221462&REV_00\3&11583659&0&D1
Driver: n/a
Name: Intel(R) ICH10R LPC Interface Controller - 3A16
Device ID: PCI\VEN_8086&DEV_3A16&SUBSYS_75221462&REV_00\3&11583659&0&F8
Driver: n/a
Name: Intel(R) 5520/5500/X58 I/O Hub to ESI Port - 3405
Device ID: PCI\VEN_8086&DEV_3405&SUBSYS_75221462&REV_13\3&11583659&0&00
Driver: n/a
Name: Intel(R) ICH10 Family PCI Express Root Port 5 - 3A48
Device ID: PCI\VEN_8086&DEV_3A48&SUBSYS_75221462&REV_00\3&11583659&0&E4
Driver: n/a
Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A37
Device ID: PCI\VEN_8086&DEV_3A37&SUBSYS_75221462&REV_00\3&11583659&0&D0
Driver: n/a
Name: Intel(R) 7500/5520/5500/X58 I/O Hub Throttle Registers - 3438
Device ID: PCI\VEN_8086&DEV_3438&SUBSYS_00000000&REV_13\3&11583659&0&A3
Driver: n/a
Name: Intel(R) 82801 PCI Bridge - 244E
Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_75221462&REV_90\3&11583659&0&F0
Driver: n/a
Name: Intel(R) ICH10 Family PCI Express Root Port 2 - 3A42
Device ID: PCI\VEN_8086&DEV_3A42&SUBSYS_75221462&REV_00\3&11583659&0&E1
Driver: n/a
Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A36
Device ID: PCI\VEN_8086&DEV_3A36&SUBSYS_75221462&REV_00\3&11583659&0&EA
Driver: n/a
Name: Intel(R) 7500/5520/5500/X58 I/O Hub System Management Registers - 342E
Device ID: PCI\VEN_8086&DEV_342E&SUBSYS_00000000&REV_13\3&11583659&0&A0
Driver: n/a
Name: 1394 OHCI Compliant Host Controller
Device ID: PCI\VEN_197B&DEV_2380&SUBSYS_522D1462&REV_10\4&1A3D4FB3&0&00E5
Driver: n/a
Name: Intel(R) ICH10 Family PCI Express Root Port 1 - 3A40
Device ID: PCI\VEN_8086&DEV_3A40&SUBSYS_75221462&REV_00\3&11583659&0&E0
Driver: n/a
Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A35
Device ID: PCI\VEN_8086&DEV_3A35&SUBSYS_75221462&REV_00\3&11583659&0&E9
Driver: n/a
Name: Intel(R) 7500/5520/5500/X58 I/O Hub Control Status and RAS Registers - 3423
Device ID: PCI\VEN_8086&DEV_3423&SUBSYS_00000000&REV_13\3&11583659&0&A2
Driver: n/a
Name: Standard Dual Channel PCI IDE Controller
Device ID: PCI\VEN_197B&DEV_2363&SUBSYS_75221462&REV_03\4&37B99283&0&00E1
Driver: n/a
Name: High Definition Audio Controller
Device ID: PCI\VEN_8086&DEV_3A3E&SUBSYS_75221462&REV_00\3&11583659&0&D8
Driver: n/a
Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A34
Device ID: PCI\VEN_8086&DEV_3A34&SUBSYS_75221462&REV_00\3&11583659&0&E8
Driver: n/a
Name: Intel(R) 7500/5520/5500/X58 I/O Hub GPIO and Scratch Pad Registers - 3422
Device ID: PCI\VEN_8086&DEV_3422&SUBSYS_00000000&REV_13\3&11583659&0&A1
Driver: n/a
Name: Realtek PCIe GBE Family Controller
Device ID: PCI\VEN_10EC&DEV_8168&SUBSYS_75221462&REV_02\4&195011B8&0&00E4
Driver: n/a
Name: Intel(R) ICH10 Family USB Enhanced Host Controller - 3A3C
Device ID: PCI\VEN_8086&DEV_3A3C&SUBSYS_75221462&REV_00\3&11583659&0&D7
Driver: n/a
Name: Intel(R) ICH10 Family SMBus Controller - 3A30
Device ID: PCI\VEN_8086&DEV_3A30&SUBSYS_75221462&REV_00\3&11583659&0&FB
Driver: n/a
Name: Intel(R) 7500/5520/5500/X58 I/O Hub PCI Express Root Port 7 - 340E
Device ID: PCI\VEN_8086&DEV_340E&SUBSYS_75221462&REV_13\3&11583659&0&38
Driver: n/a
Name: NVIDIA GeForce GTX 580
Device ID: PCI\VEN_10DE&DEV_1080&SUBSYS_15823842&REV_A1\4&34A1109&0&0018
Driver: n/a
Name: Intel(R) ICH10 Family USB Enhanced Host Controller - 3A3A
Device ID: PCI\VEN_8086&DEV_3A3A&SUBSYS_75221462&REV_00\3&11583659&0&EF
Driver: n/a
Name: Intel(R) ICH10 Family 2 port Serial ATA Storage Controller 2 - 3A26
Device ID: PCI\VEN_8086&DEV_3A26&SUBSYS_75221462&REV_00\3&11583659&0&FD
Driver: n/a
Name: Intel(R) 7500/5520/5500/X58 I/O Hub PCI Express Root Port 3 - 340A
Device ID: PCI\VEN_8086&DEV_340A&SUBSYS_75221462&REV_13\3&11583659&0&18
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_0E09&SUBSYS_15823842&REV_A1\4&34A1109&0&0118
Driver: n/a
Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A39
Device ID: PCI\VEN_8086&DEV_3A39&SUBSYS_75221462&REV_00\3&11583659&0&D2
Driver: n/a
Name: Intel(R) ICH10 Family 4 port Serial ATA Storage Controller 1 - 3A20
Device ID: PCI\VEN_8086&DEV_3A20&SUBSYS_75221462&REV_00\3&11583659&0&FA
Driver: n/a
Name: Intel(R) 7500/5520/5500/X58 I/O Hub PCI Express Root Port 1 - 3408
Device ID: PCI\VEN_8086&DEV_3408&SUBSYS_75221462&REV_13\3&11583659&0&08
Driver: n/a
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.01.7601.17514
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.01.7601.17514
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.01.7601.17514
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.01.7600.16385
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.01.7600.16385
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.01.7601.17514
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.01.7601.17514
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.01.7600.16385
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.01.7600.16385
WMT VIH2 Fix,0x00200000,1,1,WLXVAFilt.dll,15.04.3538.0513
Record Queue,0x00200000,1,1,WLXVAFilt.dll,15.04.3538.0513
WMT Switch Filter,0x00200000,1,1,WLXVAFilt.dll,15.04.3538.0513
WMT Virtual Renderer,0x00200000,1,0,WLXVAFilt.dll,15.04.3538.0513
WMT DV Extract,0x00200000,1,1,WLXVAFilt.dll,15.04.3538.0513
WMT Virtual Source,0x00200000,0,1,WLXVAFilt.dll,15.04.3538.0513
WMT Sample Information Filter,0x00200000,1,1,WLXVAFilt.dll,15.04.3538.0513
DV Muxer,0x00400000,0,0,qdv.dll,6.06.7601.17514
Color Space Converter,0x00400001,1,1,quartz.dll,6.06.7601.17514
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.7601.17514
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,12.00.7601.17514
AVI Splitter,0x00600000,1,1,quartz.dll,6.06.7601.17514
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.7601.17514
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.7601.17528
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,6.01.7140.0000
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.7601.17528
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17514
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.7601.17514
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.7601.17514
VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7601.17514
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.7601.17528
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.7601.17514
SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.7601.17528
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17514
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.7601.17514
DV Splitter,0x00600000,1,2,qdv.dll,6.06.7601.17514
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.7601.17514
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,6.01.7601.17514
ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.7601.17514
Video Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17514
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.7601.17528
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.06.7601.17514
Video Port Manager,0x00600000,2,1,quartz.dll,6.06.7601.17514
Video Renderer,0x00400000,1,0,quartz.dll,6.06.7601.17514
File Writer,0x00200000,1,0,WLXVAFilt.dll,15.04.3538.0513
VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.7601.17514
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.7601.17514
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.01.7601.17514
File writer,0x00200000,1,0,qcap.dll,6.06.7601.17514
iTV Data Sink,0x00600000,1,0,itvdata.dll,6.06.7601.17514
iTV Data Capture filter,0x00600000,1,1,itvdata.dll,6.06.7601.17514
DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.7601.17514
Overlay Mixer2,0x00200000,1,1,qdvd.dll,6.06.7601.17514
AVI Draw,0x00600064,9,1,quartz.dll,6.06.7601.17514
RDP DShow Redirection Filter,0xffffffff,1,0,DShowRdpFilter.dll,
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
WST Pager,0x00200000,1,1,WSTPager.ax,6.06.7601.17514
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.7601.17514
SampleGrabber,0x00200000,1,1,qedit.dll,6.06.7601.17514
Null Renderer,0x00200000,1,0,qedit.dll,6.06.7601.17514
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.7601.17514
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.01.7601.17514
StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.7601.17528
Smart Tee,0x00200000,1,2,qcap.dll,6.06.7601.17514
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.06.7601.17514
AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17514
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.7601.17514
Wave Parser,0x00400000,1,1,quartz.dll,6.06.7601.17514
MIDI Parser,0x00400000,1,1,quartz.dll,6.06.7601.17514
Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.7601.17514
File stream renderer,0x00400000,1,1,quartz.dll,6.06.7601.17514
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,6.01.7140.0000
StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.7601.17528
AVI Mux,0x00200000,1,0,qcap.dll,6.06.7601.17514
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.7601.17514
File Source (Async.),0x00400000,0,1,quartz.dll,6.06.7601.17514
File Source (URL),0x00400000,0,1,quartz.dll,6.06.7601.17514
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.7601.17514
Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.01.7601.17514
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.7601.17514
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.7601.17514
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.01.7600.16385
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.01.7600.16385
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.01.7600.16385
DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.7601.17514
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.7601.17514
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.06.7601.17514
Fraps Video Decompressor,0x00200000,1,1,qcap.dll,6.06.7601.17514
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.06.7601.17514
Microsoft RLE,0x00200000,1,1,qcap.dll,6.06.7601.17514
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.06.7601.17514
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,6.01.7600.16385
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,6.01.7600.16385
IMA ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17514
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17514
GSM 6.10,0x00200000,1,1,quartz.dll,6.06.7601.17514
Messenger Audio Codec,0x00200000,1,1,quartz.dll,6.06.7601.17514
CCITT A-Law,0x00200000,1,1,quartz.dll,6.06.7601.17514
CCITT u-Law,0x00200000,1,1,quartz.dll,6.06.7601.17514
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.06.7601.17514
Audio Capture Sources:
Microphone (Realtek High Defini,0x00200000,0,0,qcap.dll,6.06.7601.17514
Microphone (3- Tt eSPORTS Chall,0x00200000,0,0,qcap.dll,6.06.7601.17514
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,6.06.7601.17528
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.7601.17514
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,6.06.7601.17514
WDM Streaming Capture Devices:
,0x00000000,0,0,,
Realtek HD Audio CD input,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Realtek HD Audio Line input,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Realtek HD Audio Mic input,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Realtek HD Audio Stereo input,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Tt eSPORTS Challenger Ultimate gaming keyboard,0x00200000,2,2,ksproxy.ax,6.01.7601.17514
WDM Streaming Rendering Devices:
NVIDIA High Definition Audio,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Realtek HD Audio output,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Realtek HDA SPDIF Out,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.7601.17514
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.7601.17514
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.7601.17514
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,1,EncDec.dll,6.06.7601.17528
Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.7601.17528
PTFilter,0x00200000,0,0,EncDec.dll,6.06.7601.17528
XDS Codec,0x00200000,0,0,EncDec.dll,6.06.7601.17528
WDM Streaming Communication Transforms:
Audio Renderers:
Speakers (Realtek High Definiti,0x00200000,1,0,quartz.dll,6.06.7601.17514
ASUS VH238-1 (NVIDIA High Defin,0x00200000,1,0,quartz.dll,6.06.7601.17514
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.06.7601.17514
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.06.7601.17514
DirectSound: ASUS VH238-1 (NVIDIA High Definition Audio),0x00200000,1,0,quartz.dll,6.06.7601.17514
DirectSound: Realtek Digital Output (Realtek High Definition Audio),0x00200000,1,0,quartz.dll,6.06.7601.17514
DirectSound: Speakers (3- Tt eSPORTS Challenger Ultimate gaming keyboard),0x00200000,1,0,quartz.dll,6.06.7601.17514
DirectSound: Speakers (Realtek High Definition Audio),0x00200000,1,0,quartz.dll,6.06.7601.17514
Realtek Digital Output (Realtek,0x00200000,1,0,quartz.dll,6.06.7601.17514
Speakers (3- Tt eSPORTS Challen,0x00200000,1,0,quartz.dll,6.06.7601.17514
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
Quality Flags: 2576
Enabled:
Force throttling
Allow half deinterlace
Allow scaling
Decode Power Usage: 100
Balanced Flags: 1424
Enabled:
Force throttling
Allow batching
Force half deinterlace
Force scaling
Decode Power Usage: 50
PowerFlags: 1424
Enabled:
Force throttling
Allow batching
Force scaling
Decode Power Usage: 0
More about : wow graphics problems
I havent played in awhile but I remember having default UI problems similar to that as well that required me to reload my ui but maybe not as often as you described.
Do you play any other games that you experience those weird pixelated/colored boxes?
Also when did you start having the issue? I noticed that your drivers were recently updated
Related ressources
Even if you run those other games in admin mode?
It's weird that I had a similar situation to this about a year ago where I had discolored pixels, screen tearing and other weird things ONLY in WoW that ended up being a video card going out. It eventually gave totally out one day, went to replace it and never had the problem again.
Oh I dont play the other games in admin, they work perfectly fine without running as admin so I don't even bother.
You think it might be a problem with running as admin? What would cause that?
I hope it's not video card going out it's only a couple months old and don't feel like paying those crazy shipping fees lol =/
Best solution
It may not be the video card going out at all, its always the last resort of course. (Sorry to scare you with the story)
Running as administrator in Windows really shouldnt do much, it just allows the game or whatever program to possibly access different paths or open without permissions. In your case, it seems to possibly by opening the game and using a different driver path maybe? WoW is weird in how it runs from what I remember.
(This is a long shot) Try to maybe redownload the latest drivers and install them as admin if you can.
Ask the community
