Tom's Hardware > Forum > Systems > HP > Problem with serial console
Forum Systems : HP - Problem with serial console
Archived from groups: comp.sys.hp.hardware (More info?)
Hi
I have a HP9000 E35 E-Class Server, I cannot get any prompt whatsoever.
There is no graphics card and I'm using a
8 Port MDP "Modem" Connected to a SCSI/PRINTER/APMUX16 Board have set my
terminal to 8N1 9600 and tried both hardware and software handshaking to
no avail. When the server is powered up there is activity of the "Link
status" led on the modem during boot up. There is some drive activity that
sounds like it's booting up. Any ideas on what to look for. Other possible
settings etc.??
Thanks in advance,
Dave
daveh@allheller.net
Using Opera's revolutionary e-mail client: http://www.opera.com/m2/
Sponsored Links
"Dave_the_rave" <junk@allheller.net> wrote in message
news:op.svblgsfrz4ekm1@fast.land-5.net...
> Hi
> settings etc.??
> Thanks in advance,
> Dave
> daveh@allheller.net
What kind of terminal? 700/92? Check emulation....make sure it isn't VT.
Also check console is in "Remote". Think its softkey F4 on 700/92.
Reply to Anonymous
>> Hi
>> that
>> possible
>> settings etc.??
>> Thanks in advance,
>> Dave
>> daveh@allheller.net
Thanks
It's a 700/96 Emulation set for HP emulation and console is in "Remote"
mode
Still nothing appears on terminal.
Dave
Reply to Anonymous
news:op.svgf83jwz4ekm1@fast.land-5.net...
>>> Hi
>>> that
>>> possible
>>> settings etc.??
>>> Thanks in advance,
>>> Dave
>>> daveh@allheller.net
> Thanks
> mode
> Dave
Sorry Dave.... end of my "old" knowledge. The only other two things I can
think of (and Im hoping someone else will elaborate) is 1. The cable between
VDU and Mux panel. Is it the right one? and 2. IIRC there was a fuse in the
mux panel I think, surface mounted, looked just like a normal component,
cant be certain and not sure what the symptoms were if it went OC.
Sorry.
Reply to Anonymous
There are 1217 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
