Advices on wireless switches.
Forum Wireless Networking : Wireless General Discussions - Advices on wireless switches.
Archived from groups: alt.internet.wireless (More info?)
Hi
My company will install some wi-fi AP and I am search some infos
on wi-fi switches
I've read some docs about them but have no practice of it ...
I saw Extreme-networks products which seems very interresting
Any infos/feedback welcome.
Thanks
Sponsored Links
"frank" <frank@dev.null> wrote in message
news:41c162fd$0$3517$4d4eb98e@read.news.fr.uu.net...
> Hi
> on wi-fi switches
> Thanks
There are quite a few new wireless switches on the market.
Most provide for centralized management of all the AP
like upgrading firmware, load balancing etc. The move is in the
direction
of Thin-APs (less smarts, less expensive) with the switch being the
brains.
Some of them are using proprietory technology which means
you will probably need to use their APs also to take full advanage
of the switches capabilities. The Extreme switch (uses proprietory
technology)
There are others: It just depends on your budget.
http://www.airespace.com/
http://www.symbol.com/
http://www.cisco.com
http://www.trapezenetworks.com
How many Aps are you going to install?
Reply to Anonymous
You should also check out chantrynetworks.com - they are using routing
rather than switching and in the long run that should be more
versatile.
wiology2004
brought to you by http://www.wifi-forum.com/
Reply to Anonymous
Hi, can you explain why you think routing at L3 is better
than L2?
> versatile.
Reply to Anonymous
>than L2?
Layer 2 is bridging, not routeing.
Layer 3 is routeing.
(Is it routeing or routing?)
A bridge has no concept of CIDR or netmask. Therefore, you can't just
say "take all the traffic on this here network and shove it through a
gateway over to yonder network". That's easy with a router. With
bridging, each MAC address is unique with no guaranteed commonality
with other machines on the same network. Therefore, to do routeing on
Layer 2, you would need a route for every single last lousy MAC
address on the network. That's not very practical or useful.
Also, with bridging, the manufactory assigns the MAC address (although
it can be changed). With routeing, the network admin or the DHCP
server assigns the IP address, giving much more control over
organization, topology, and routeing on Layer 3.
Also, Layer 2 has no concept of services, such as http, ftp, telnet,
etc. Layer 3 routeing allows you to control traffic by these
services. Layer 2 only knows about ethernet and cannot distinguish
the different types of traffic.
ALL (and I do mean all) wireless contraptions are Layer 2 bridges. A
wireless bridge know nothing about Layer 3 (TCP/IP) features and
functions. All it knows is ethernet and MAC addressing. If the
destination MAC address is across the bridge, the traffic will pass
over the bridge. If not, it won't pass. More simply, all 802.11
wireless does is encapsulate 802.3 ethernet packets, send them over a
radio link, and reconstruct the original 802.3 ethernet packets at the
destination end. Crudely, it's an extension cord for ethernet.
A wireless router is nothing more than a wireless bridge with an
ethernet router glued onto one of the wireless (switch) ports. The
function of the router is quite independent of the wireles bridge
section.
# Jeff Liebermann 150 Felker St #D Santa Cruz CA 95060
# 831.336.2558 voice http://www.LearnByDestroying.com
# jeffl@comix.santa-cruz.ca.us
# jeffl@cruzio.com AE6KS
Reply to Anonymous
>>than L2?
Yes, i didn't say L2 was routing.
The latter.
I don't think it is all. Chantry supposedly works at L3. There's no real
reason to have L2 work at all. It's just easier because the
chips do the mac learning for you. I think L3 is really the way to go.
Let the AP proxy arp for all the ip addresses used by the station.
Then there's no possibility of arp poisoning attacks.
Reply to Anonymous
>The latter.
Ok. Google shows 53,000 hits for routeing and 15 million hits for
routing. Routing wins.
First let me apologize. I could not divine your level of expertise
from your two terse messages. Therefore, I assumed[1] that you were
asking a beginners question and did not understand the difference
between bridging and routeing, er.. routing. Obviously I misread the
question. Sorry.
I've never considered the possibility of locking the MAC layer and
doing eveything at the IP layer. I agree, it seems like a good idea.
The FAQ covers the benifits:
http://www.chantrynetworks.com/sit [...] rt/faq.asp
It certainly would fix the roaming and portable IP problem as well as
block various layer 2 attacks.
[1] Assumption, the mother of all screwups.
Jeff Liebermann jeffl@comix.santa-cruz.ca.us
150 Felker St #D http://www.LearnByDestroying.com
Santa Cruz CA 95060 AE6KS 831-336-2558
Reply to Anonymous
- 0 +
thanks for all your answers guys.
Reply to frank
Dictionary.com is authorative for me. On the net I find too many people
are as bad a speller as I am :-)
No need to apologize. I look forward to your posts.
I also hope you do a book someday of your exploits.
They are always interesting.
Reply to Anonymous
I usually use dict.org. It's not just the spelling. I'm also having
problems with the pronounciation. On the left coast, it's pronounced
"rou-ter". In the UK, it's "roo-ter". In the south, it's "rou-tah".
I've also heard "rah-ter" but I didn't ask where that came from.
It will probably not happen. I have a friend that scribbles computah
books and others that do self-publishing. Both require substantial
self-promotion, travel, book signing, investments, and time. After
watching how it's done, I don't think I can do all that. I'm not very
presentable, detest travelling, and am quite lazy. I know of one
author that hired a stand-in to do all the hand shaking, book signing,
and pose for the cover liner. However, that drastically reduced the
book revenue. I do have some ideas for a book, but they have nothing
to do with wireless, computahs, or the internet. Thanks for the
interest.
Reply to Anonymous
Well, some people pronounce "root" with a vowel sound similar to that in
"book". The pronunciation of "route" that rhymes with "out" instead of
"boot" is a regional one that has, unfortunately, spread in the United
States. To me, the word pronunced that way means a military disaster or,
for the "er" form, a carpenter's tool. The standard American
pronunciation used to be the one in the theme song from the 1960s
television series: "Get your kicks / On Route 66."
Reply to Anonymous
Tom's Hardware > Forum > Wireless Networking > Wireless General Discussions > Advices on wireless switches.
There are 1157 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
