Tom's Hardware > Forum > Motherboards & Memory > General Motherboard > ECS K7S5A MOBO Problems-- Please HELP!
I just set up my new system:
ECS K7S5A MOBO
AMD Athlon 1.33GHz
512MB PC2400 DDR-SDRAM
Promise FastTrak RAID
The problems I am having are:
1. It will not get past the RAID diagnostic if I have my USB mouse plugged in (it does boot if the mouse is on an adapter in the PS-2 hole),
2. Any time I try to copy the flash program and BIOS onto a floppy, it freezes up my system,
3. The flash program (AMI8188) generates protection fault errors (yes, it is within DOS, not just a DOS window).
Please advise!
<font color=blue> There ya go. </font color=blue>
Sponsored Links
Attempt trying to flash with out the raid card installed and a ps2 mouse. Unzip the zip file directly to a floppy.
A little bit of knowledge is a dangerous thing!
Reply to Ncogneto
I did it, but I got error messages after trying to run the flash program. No dice. Any other advice?
Reply to Anonymous
Does your motherboard have the onboard Lan and are you sure you are trying to flash the correct bios?
Video editing?? Ha, I don't even own a camera!
Reply to Ncogneto
Yes, it does, and yes, I am. I'm beginning to think there's a conflict between this chipset and my RAID. Suggestions?
Reply to Anonymous
<A HREF="http://forum.ocworkbench.com/ocwbcgi/ultimatebb.cgi?ubb=get_topic&f=4&t=000002&p=" target="_new">http://forum.ocworkbench.com/ocwbcgi/ultimatebb.cgi?ubb=get_topic&f=4&t=000002&p=</A>
Reply to Ncogneto
Still no dice! When I try to run the app from DOS, I get a general protection fault error and a bunch of memory addresses. What's up with this board, anyway?
Reply to Anonymous
I really couldn't tell you mine flashed no problem. when you say from DOS just how are you achieving pure DOS mode? A boot disk correct?
Reply to Ncogneto
Yeah, pure DOS. Is this problem typical of ECS K7S5A boards?
Reply to Anonymous
There are 1270 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
