Tom's Hardware > Forum > Wireless Networking > Wireless General Discussions > WAG54GWireless G ADSL Gateway problem
Forum Wireless Networking : Wireless General Discussions - WAG54GWireless G ADSL Gateway problem
Archived from groups: alt.internet.wireless (More info?)
I have had my WAG54G Wireless - G ADSL Gateway set up and in
operation for about 3 months. It was working very well until
yesterday. The DSL Internet light switched from green to red and
my connection has been down since.
I tried to go to the configuration address, http://192.168.1.1/
and check the settings, but can not get through to this address.
I get an error message screen that says the site is not
available. What am I doing wrong, or failing to do right? Any
suggestions???
I'm down to my dial-up connection, and getting anxious.
Sponsored Links
If you can't connect to 192.168.1.1 then this implies that your PC IP
address isn't valid for your LAN subnet.
Apparently if the PC can't get a valid IP address from the DHCP server then
it uses a 198 (?) address. This seems more likely to happen if you connect
through a wireless link to the WAG54G rather than through a wired link.
So:-
Try connecting via a wired link, then check your WAG54G settings for
username, password, etc
These could have been lost if :-
-someone had reset the WAG54G making it lose these settings.
-you left remote administration turned on, and a hacker has adjusted
them for you.
If you still can't connect then you could try resetting the WAG54G and
re-entering the parameters from scratch.
Ummm have you paid your broadband bills recently?
Hope this helps
"Gordon" <gordonlr@DELETEswbell.net> wrote in message
news:sig6s0t507vogc85uh5q587hsrgrer3vsn@4ax.com...
> suggestions???
Reply to Anonymous
On Fri, 17 Dec 2004 21:06:56 -0000, "nospam" <me@privacy.net>
>So:-
>them for you.
>Hope this helps
Thanks for this response. I will try to give you more information
to go on.
My first thoughts were that I was in trouble because I had
changed my password for my internet service. I did the password
change, using this computer. But, I didn't open the WAG54G setup
screen and change the password there, if that is a requirement.
The DSL failure didn't show up until a day or so later, but this
may be because the DSL service never blinked during this time, so
a new connection did not have to be established. And, yes, I am
paid up with my DSL service provider. This is a part of my
regular phone bill, which is direct debited to my checking
account and paid almost instantly, when the phone company submits
their bill.
I am not able to get into the Linksys Setup screen at all, so I
can not verify any of my settings. A printout that I made several
months ago, when I first set this up shows that I changed the
Local IP address from 192.168.1.1 to 109.113.132.134. I don't
remember just why I did this, but it may have been because of
some other problem and I was just groping for a work-around.
Anyway, I can't get to the Setup screen even with this Local IP
address.
I'm presently working from and through my desktop, which is wired
to the WAG54G, not through a wireless link, although I have tried
getting through with my laptop and the other desktop, both of
which are wireless connections. Same thing...I can't get to the
Setup screen. I've never had remote administration turned on, so
this surely isn't the source of the problem.
When I turn the WAG54G off, then turn it back on, the green
lights all blink in accordance with the information given in the
manual. The only thing that fails to go to completion is the red
internet light never turns green.
The WAG 54G has not been reset. This is a three computer home
network setup, and I'm the only one that messes with the WAG54G
setup. I haven't touched the reset button.
All three computers can communicate with each other, so the local
setup is not malfunctioning. I just can't get my DSL connection
up and running. But, I can dial-up through this same phone wall
outlet, so there must not be a problem with the phone line.
Can you think of anything else I can try before I give up and
punch the reset button?
Thanks for your help.
>> suggestions???
Reply to Gordon
1. Ahhhh - you need to change the login password to the ISP on the WAG54G -
it is doing the connection to the ISP, not your PC. This probably explains
why you can't connect to the net through the WAG54G.
2. Is 109.113.132.134 in the range reserved for local subnet addresses? The
192.168.x.x range definitely is, but I'm not sure about 109.113.x.x and I'm
not sure what the effect of using it would be. I would stick with the
192.168.x.x range, at least until you've got it working again.
3. Get the wired connection working first, before moving on top the wireless
connection. If you can't connect to the WAG54G (using a wired connection)
then this implies that your PC IP address isn't recognised as part of your
subnet by the WAG54G. Are you using DHCP - on both the WAG54G and your PC?
Or if you are allocating the IP address statically then is it set to a
suitable value?
4. If you still aren't connected then I would be tempted to reset the WAG54G
(hold the reset button down for 10 secs) and then re-enter al parameters.
You will need to know your ISP username, password, VPI and VCI - your ISP
can tell you suitable values for these.
news:5bl6s0tfmk5ndchibil45vac7k9ppv2ftg@4ax.com...
>>then
>>connect
>>So:-
>> adjusted
>>them for you.
>>Hope this helps
> to go on.
> their bill.
> address.
>>> suggestions???
Reply to Anonymous
> suggestions???
Hello there!
If you updated the Linksys setup file, you'll have to do a full reset (back
button, hold it down for 10" ).
Then hook up again with your PC to the router and start from the beginning.
It happened to me too and now it's working just fine, very powerfully
indeed:
I can pick up the signal from my garage which is 4 floors down in the
basement!!!
Cheers,
Steffo
Reply to Anonymous
On Sat, 18 Dec 2004 13:21:55 +0100, "Steffo" <steffo@nospam.com>
>> suggestions???
>Hello there!
>indeed:
>basement!!!
>Cheers,
>Steffo
Is this by any chance a Windows XP SP2 related problem? I was
accessing my Web-Based Utility at IP Address 192.168.1.1 on a
regular basis a few months ago, when I first set up my home
network. I have SP2 installed, and haven't had any problems that
I can identify with it.
Incidentally, this set of problems pertain to three computers in
a home network. All three are running Windows XP SP2. I have my
desktop computer cable connected to the WAG54G, my notebook
connected by a Linksys Model No. WPC11 Wireless-B Notebook
Adapter, and my wife's desktop computer connected by a Linksys
Model No. 54Gv4 Wireless-G PCI Adapter
I set up my home network a few months ago, and, once I got things
up and running like we wanted them I had no need to open this
Web-Based Utility, until I tried to change my ISP password.
After the password had been changed on my ISP server I thought
all was well, but two days later my LinkSys WAG54G Wirelses-G
ADSL Gateway must have dropped its connection. It never could
re-establish the connection.
I then used my dial-up to restore my old password on my ISP
server, and the WAG54G picked the connection up promptly.
But, I still want to change my password on my ISP server. To do
this I need to be able to coordinate this change with the WAG54G
password. Unfortunately, I can't access the IP address
192.168.1.1 the way I used to be able to.
I did a Start - Run - cmd.exe to open the command processor, then
keyed in ipconfig /all to get a reading on my Windows IP
Configuration settings. This window shows my Ethernet adapter
Local Area Connection as follows;
Description .....: Linksys LNE100T100TX Fast Ethernet
Adapter<LNE100TX v4>
Physical address...: 00-0C-41-EE-59-46
Dhcp Enabled...:No
IP Address...: 192.168.1.1
Subnet Mask...: 255.255.255.0
Default Gateway...: 151.164.23.201
DNS Servers...: 151.164.1.8
Everything seems to be in order here, but when I key the IP
address into my browser's address slot I get an error page saying
this site can not be found.
Reply to Gordon
192.168.1.1 is the default IP address of the router.
The ipconfig info shows the IP address of your PC - which it is reporting as
192.168.1.1 - ie the same as the router!
Assuming that you haven't changed the default IP address of the router then
your PC shouldn't have that IP address.
Either:-
1. You have your pc ip address statically allocated to 192.168.1.1 - this
should be something on the same subnet, and different from the router IP
address - in which case setup a good IP address on your pc.
or
2. Your PC is set up to get IP addresses dynamically, and your router is
configured to dole out ones that clash with itself. - in which case reset
the router so that it gets a 192.168.1.1 address and doles out IP addresses
in the range 192.168.1.50 - 100 to requesting PCs.
news:0gp8s012vcndsm146cobb72luuvcugb0cd@4ax.com...
>>> suggestions???
>>Hello there!
>>(back
>>beginning.
>>indeed:
>>basement!!!
>>Cheers,
>>Steffo
> Dhcp Enabled...:No
Reply to Anonymous
On Sat, 18 Dec 2004 19:57:09 -0000, "nospam" <me@privacy.net>
wrote:
Problem resolved...I think. I believe my pop-up blocker was
indiscreetly blocking my access to the Linksys Wireless-G
Gateway's IP. When I turned my pop-up blocker off I was able to
key in the IP in my browser's address slot and open the site. I
still don't understand why I was getting those error messages
"The page cannot be displayed" instead of the usual message
stating that my pop-up blocker had blocked this site.
Not, I have to figure out just how to simultaneously change the
password on my ISP server and in my Wireless router so there
won't be a conflict. If I change the password on my ISP server
first, my DSL connection will probably drop dead. I guess I can
then open the Linksys IP address and change the password there,
without having an active DSL connection up and running.
>Either:-
>or
>>>> suggestions???
>>>Hello there!
>>>(back
>>>beginning.
>>>indeed:
>>>basement!!!
>>>Cheers,
>>>Steffo
>> Dhcp Enabled...:No
Reply to Gordon
There are 782 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
