G
Guest
Guest
Hi Guys,
I've been battling with this problem for about 4 weeks now
I have tried to put everything here I have done - I hope its not too long
I recently upgraded my machine with a 1.4 gig AMD chip, Elitegroup K7TA3 mobo, radeon 64 ddr agp and DDR ram.
All appeared ok, but when a few apps were open my system would hang for a few seconds - I ran a CPU monitor and it showed it running at a constant 60 - 80% usage, going off the scale when an app was opened and hanging.
After reformatting a few times, trying with ME and 98SE, stripping the machine down to bare bones, and having the same results even immediately after a clean install, I returned the stuff to the shop.
At the shop they replaced each component one by one and had the same problem, they even tried another mobo, an MSI ddr board and a geforce 2 gts card and got the same results - after about 3 days they used the CPU MON on the DDR systems they are building from new and found them to have the same problem - which they then decided wasn't a problem and must be a charcteristic of the DDR mobo setups - I think thats bollox (imho)
They then gave me my box back and as far as they are concerned that is the end of it - its meant to be like that
This is exactly what I have done in constructing the new pc
1) Set the mobo jumper from 100 mhz to 133mhz
2) Fitted Mobo and attached 512 of DDR ram in sockets 1 and 2
3) Fitted 30 GIG ATA 66 HD to IDE slot 1, set as master
4) Attached floppy and cable to floppy socket
5) Attached HP CDWriter PLus 9300 to second IDE socket set as master ( I even removed this and rebooted but no change)
6) Attached Radeon DDR card to AGP slot
7) Inserted boot disk into floppy and started machine
8) On DOS promt, formatted C drive and subsequently installed Windows ME
9) Once first boot was complete - before installing any drivers, I opened one of a couple of CPU monitors and the CPU was jumping around at between 60 & 80 % usage.
10) After installing all drivers for mobo, 4 in 1 chipset stuff, card drivers etc - still the same
11) Downloaded and updated to latest mobo bios - still the same
Can anyone help me with this, has anyone got a 1.4 ddr machine they could run a CPU mon on to see if they have the same prob?
TIA
stubbsy
TIA
stubbsy
