G
Guest
Guest
Right now I'm running a intel PIII 600 at 100 Mhz/bus and soon I plan on upgraded my CPU and Motherboard, but I'm a little confused what to get. My question is that if I ran my FSB and overclocked it 2 say 133 and I had PC-100, wouldn't that essentially be overclocking my SRAM. I don't have this problem, but I'm using it as an example. Some of the new MOBO have 200/266 bus speeds how are they not overclocking the RAM, I'm aware that they make PC/100/133/150 but how do you run at these higher speeds. I might be wrong, but I thought that SRAM is dictated by the system bus speed, I'm confused do these boards use DRAM, does that work independant of the bus, or what? I hope not because I'm trying to go the economical route. thanks.
