A7V-133- 1.4Ghz Problem
G
Guest
Guest
I just bought a Thunderbird 1.4Mhz CPU and installed it on my A7V-133 Raid motherboard I cannot even get a post. I turn the system on on the fan spins then the system cuts off leaving with a blinking Green Led light on the power button. I upgraded the bio's to the latest and still no post. My 850MHz Thunderbird works fine, no problem their.
I even reset the bio's to default still no post.
Can Anybody help me with this problem.
System
Motherboard:A7V-133 Raid
Memory:448Megs
Video:Gforce 32 Megs
HD: 30 Gigs
Sound:SBlaster 128
btvillarin
2,370
I'm assuming that with your 850 T-Bird, you used the jumperless mode to have your CPU settings. I suggest that you change into Jumpered Mode. (See page 18) Then, set your multiplier to 10.5 and your front side bus to 133. That should be about 1400MHz.
Let me know if that works... :smile:
