Tom's Hardware > Forum > Motherboards & Memory > General Motherboard > problem with new mobo\cpu.. please help
Forum Motherboards & Memory : General Motherboard - problem with new mobo\cpu.. please help
I recently purchased a new Motherboard and a new cpu. I have had lock up problems constantly. Sometimes it will run for 2 hours. Sometimes 2 seconds. But it always locks up. I've tried swapping out every component(vid card, sound card, hard drive, cd rom, disk drive, etc.)and even tried multiple operating systems (win98/win98se/win2000pro), but nothing has worked with this new mobo/cpu combo. It doesn't seem to be an overheating problem, because my pc doesn't get above 65 degrees, according to BIOS. The only thing that I can think of is that I'm not supplying enough power, as my power supply is only 250watt. Here are my system specs:
ECS KT133A
Athlon(3) 266 1.2ghz
256 mb pc133 dimm chip (micron cas2)
Geforce 2 GTS 32mb
a couple of nic's
Maxtor 40gb hard drive
Creative Sound Blaster Live!
generic disk drive
50x cd rom
Should I go buy a new power source? I'd hate to waste the cash, if power inadequecy couldn't be the source of my lock ups. Thanks in advance.
Sponsored Links
You should be using a minimum of a 300w psu, prferably 350w.
/Please God... Change the Sig O' the Week/
Reply to Anonymous
If you can live without it, I recommend you rma the motherboard back to the vender. It may take 2-4 weeks to get a new one, as the old one will have to be tested. You might be wasting your money on a new power supply. I use a 235 watt sparkle, and have my 1.2 running at 1.33 with no problems. What brand power supply do you use? Are you overclocking?
Reply to o1die
There are 907 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
