Archived from groups: microsoft.public.windowsxp.perform_maintain (More info?)
Hello,
I have no space left on my hard drive -- from a 53GB hard drive I have 578MB
left.
I design and use digital images in my work.
I Defrag regularly and do the necessary maintenance requirements
I have deleted files no longer needed
I have emptied Recycle bin
Used disk clean up
temp files deleted
Scanned for viruses.
Yet still when I go to owners folder I have 43GB used.
Having gone through each folder found in the owners folder - cookies,
desktop, favourites, my documents etc, and checking on the properties in no
way should the total of these files fill my hard drive
The largest file is My Documents at 4.3GB
I hope that someone can put me straight and help me out. Thanks
>-----Original Message-----
>Hello,
>left.
requirements
>Used disk clean up
>temp files deleted
folder - cookies,
Thanks
>Patbatch
>And you added up the GB size of your Add/Remove programs?
Thanks for the response.
I have just added up programs they come to a little over 2.6GB
What do you think I could do next?
> >Hello,
> >left.
> requirements
> >Used disk clean up
> >temp files deleted
> folder - cookies,
> Thanks
> >Patbatch
